-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   EX1R slo-mo (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/499322-ex1r-slo-mo.html)
Robert Bobson August 7th, 2011 02:27 PM
EX1R slo-mo
Wondering if there's any difference in quality shooting:
1) 1280 60p @ 60fps - then slow down to 30fps in timeline
2) 1280 30p @ 60fps - already appears slow in timeline
anyone know if one method is "better" ? or saves on memory?
I'm guessing they're the same
Olof Ekbergh August 7th, 2011 02:55 PM
Re: EX1R slo-mo
You loose audio when over/under cranking. But not with 60p.
And I think the bit rate is higher when over cranking vs 60p. Someone can correct me if I remember wrong.
Robert Bobson August 8th, 2011 05:37 AM
Re: EX1R slo-mo
ahhh - thanks!
Walter Brokx August 9th, 2011 03:51 AM
Re: EX1R slo-mo
Olof is right:
overcranking does not record sound.
And it takes twice the memory: it is saved as if it is a 30fps file twice as long as the recorded time.
Imagequality wise overcranking gives you the better image.
Plus you don't need to reinterpret the footage in your NLE.
Robert Bobson August 9th, 2011 03:57 AM
Re: EX1R slo-mo
"Image quality wise overcranking gives you the better image."
Why would this be?
Dominik Krol August 9th, 2011 06:14 AM
Re: EX1R slo-mo
Because you have 35 Mbps. But in overcranking a second is 2 seconds long.
Robert Bobson August 10th, 2011 06:25 AM
Re: EX1R slo-mo
still don't understand - why is overcranked quality better?
Olof Ekbergh August 10th, 2011 06:47 AM
Re: EX1R slo-mo
When the datarate is higher there is less compression, so the images are cleaner.
Over cranking uses a higher bitrate that is the reason it is cleaner.
Dominik Krol August 10th, 2011 09:31 PM
Re: EX1R slo-mo
Ok to put it more clear. You are recording at 35 Mbps (Mega bits per second) that is the compression of the file. When you overcrank to 50/60 Fps, you will get 70 Mbps. Twice the data rate = Half as much compression = twice the amount of information kept = Better image.
Andre Bernet August 13th, 2011 01:12 AM
Re: EX1R slo-mo
But in the weird bitrate scheme of those XDCAM EX cameras, a (non-overcranked) 35Mbps 720p60 stream is actually already less compressed than a 1080p30 stream that the camera also saves as 35Mbps, which is used as standard... having 70Mbps for the same is pretty much overkill.
I've checked the difference between the 2 ways to do it, and frankly I couldn't notice any difference in quality. Knowing I still have sound, and don't have files that are twice as big to store, I prefer the 720p60 route.
That might depend on the NLE you use too, personally in Premiere it's just a matter of setting "Interpret Footage" to 30fps (or 25 in my case for PAL), and that's it, no rendering time or other drawbacks, it's done on the fly.
Walter Brokx August 13th, 2011 06:31 AM
Re: EX1R slo-mo
Another benefit of shooting overcranked is that you can immediately review the clip on camera in slowmotion. This way it's easier to check whether the shot is any good as slowmo.
