-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   IR filter AND polarizer? (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/492385-ir-filter-polarizer.html)
Annen James February 28th, 2011 08:16 AM
Hello,
I need to use a polarizer for an upcoming water shoot. My EX1 lives with it's IR filter on. Should I stack the filters or drop the IR when using the polarizer? Thanks!
Marcus Durham February 28th, 2011 08:53 AM
Re: IR filter AND polarizer?
As a rule the less glass in front of the lens the better.I take my IR off if I require another type of filter.
Duncan Craig March 1st, 2011 06:26 AM
Ditto, I don't have the IR on unless I need it.
Annen James March 1st, 2011 12:19 PM
When would you not want an IR on? I guess I shoot a lot of people with black shirts, but I never take it off.
Duncan Craig March 1st, 2011 02:36 PM
I can film most jobs without it, and unless there's a situation where there are multiple black and the colours are all different I'll leave it off. It loses light too, over a stop I expect.
We shoot in a clothing store a couple of times a month with mixed lighting. Roof fluorescent, some daylight, Arri MSRs and Coollights LEDs and fluorescents.
We watch every shot while setting up, occasionally there's a black fabric that causes the IR problem, but it's quite luckily rare. And it always seems the MSRs are the source which makes it worse, probably because they have such a high CRI whereas the Coollights stuff has less red at source.
Marcus Durham March 1st, 2011 03:30 PM
It's only blacks where man made fibres are used. It's important to have the IR filter to hand but I only put it on when I need it.
I do however leave a UV filter on at all times (except if I am using another filter). I'd rather scratch or damage that than the EX1 glass.
Malcolm Hamilton March 1st, 2011 08:55 PM
Marcus - what UV filter do you use?
thanks, Malcolm
Marcus Durham March 2nd, 2011 02:01 AM
thanks, Malcolm
It's a Tiffen.
Malcolm Hamilton March 2nd, 2011 09:51 AM
Thanks very much. I think I'd better get one (it was on my wishlist, but I'd forgotten until I saw this thread).
Regards, Malcolm
Marcus Durham March 2nd, 2011 02:42 PM
You'd be amazed how much crap collects on the UV filter. When you keep in mind that all this would be going onto your expensive lens it's a no-brainer.
But you do need to keep it clean. Very clean. Also watch out for reflections when there are bright light sources.
