-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   EX3 manual white balance problem (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/492334-ex3-manual-white-balance-problem.html)
Brent Hallman February 26th, 2011 10:49 PM
Alright, here is the issue:
Last night I was shooting a sporting event inside an arena. I was using my EX3 with my Nanoflash.
I set my manual white balance with a vortex media warm card under the lights in the middle of the court before the game.
I was recording for about thirty minutes...then the camera thought it knew better than me and preformed and AWB during the middle of my shoot! I did not touch anything, the manual balance was still selected.
This has happened to me once before, now it is starting to tick me off. I was just getting b roll, so I can colour balance in post, but it is a pain.
Does anyone have experience with this/know what is going on?
Brent
Matt Davis March 1st, 2011 08:44 AM
Re: EX3 manual white balance problem
Would that have been position B?
There's an option to set position B to AutoTrace White.
However, you can still hit the White Set button. As you've found, that doesn't prevent the the camera from getting distracted and letting the colour temp drift off...
Brent Hallman March 1st, 2011 10:38 AM
Thanks for the reply Matt,
The camera was set to position 'A'..... so that is why I am confused...the camera should not be doing a balance by itself in that position.
Hirata Tomoki March 6th, 2011 08:15 AM
I had same experience too! EX1R
Alister Chapman March 6th, 2011 10:35 AM
Just a thought.... there wasn't a change to the power going to the lighting of the arena? I've see quite large swings in colour temperature when the mains voltage has fluctuated or possibly the lamps have been dimmed.
It would be more worrying if the white balance change was happening mid shot under sunlight.
Brent Hallman March 6th, 2011 11:33 AM
Alister,
I balanced under the lights on the floor of the arena...then after awhile I went up into the stands to get a different angle.
The lighting in the stands was quite dim compared to that of the arena floor where I was still aimed and recording at.
I can see how that may affect the White Balance if I had it set to the ATW position....but why would it change on me if I set the white balance manually in position 'A'?
It's happened twice to me, both in arenas, in the same kind of shooting environment (balanced under the lights on the floor, then record up in the stands).
-Brent
Alister Chapman March 6th, 2011 01:46 PM
If the lighting in the arena is on dimmers or some other control panel it is possible that the white balance can change as any dimming or control of the lamps can lead to a change in color temperature. It may or may not be your issue, just throwing in some options.
Dana Kupper March 6th, 2011 02:55 PM
Please forgive me if this does not help, but sometimes I hit buttons on my camera while carrying it, or climbing stairs, or whatever. If you accidently hit the white balance calibration button on the front, it would activate the procedure without you knowing, especially if you are carrying the camera and not looking through the eyepiece. Maybe you could put a protective cover over the button with cardboard and tape and see if that helps?
Hirata Tomoki March 7th, 2011 02:25 AM
I think it is not an accident, in my case, I shooting in outdoor (snowing day) and use manually white balance position "A" (I never use AWB, also position "B" is set at Non-AWB already on the menu), EX1R suddenly jump to another white balance, luckly, the difference is big, so I note it immediately. May be you can tell me it is cause of low temperature, the temperature of that day is -3C
Brent Hallman March 8th, 2011 02:10 PM
To respond to Alister: Lights were constant throughout the whole game, no changes in brightness, everything was stable.
To Dana: I did not touch anything, the camera was on the tripod while I was recording and I was very aware of all of my settings during filming.
To Hirata: Both times it happened to me, I was inside...about 20 Celsius.
I think the next time I'm at the repair shop I'll get them to take a look.
Thanks for the input everyone.
