-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   EX1 shuts down or reboots by itself! (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/487774-ex1-shuts-down-reboots-itself.html)
Piotr Wozniacki November 20th, 2010 09:47 AM
It happened to me a couple of times recently that my EX1 switched off, or rebooted, by itself during a shot.
I was suspecting the battery and cables, but after experimenting with several other batteries, and building a new custom cable (a one that feeds the nanoFlash and a LED light from the battery's D-tap socket) - I can safely say the culprit is somewhere else.
Luckily enough, I still do have the (extended) Prime Support warranty - but would appreciate your suggestions as to the possible reasons of such behavior.
TIA,
Piotr
Dean Sensui November 20th, 2010 01:09 PM
Nothing like that happened to either of my cameras. Let us know what it turns out to be.
Walter Brokx November 23rd, 2010 04:42 AM
Didn't you report increasing noise as well?
Maybe your circuits are corroded.... that would be bad news.
A firmware malfunction seems a bit of a strange option, (or did you shoot NSFW-websites? ;-) ) but maybe reinstalling the latest firmware might help. Make sure to download it, in case an error is in that file. BUT maybe it's unwise to install the firmware when the firmware is the problem... it could brick your gear.
(BTW, I have no clue what is wrong with your camera: I'm speculating and hopefully you will find out real soon.)
Bram Corstjens December 2nd, 2010 09:07 PM
You advise the guy to do a firmware upgrade on a camcorder that randomly shuts down or reboots???
Alastair Traill December 3rd, 2010 05:57 AM
Could it be poor contact(s) in the main power switch?
I do not know what the power switch is like in the EX1 but I am not impressed with the one on the EX3 - it is a little vague for my liking.
Piotr Wozniacki December 3rd, 2010 06:07 AM
My problem (and the reason I still haven't sent the camera to Sony) is that the reboot only happened once; it did shut off more than once but - as I said in the OP - I thought it was my battery, or the custom cable I was using...
I'll keep you posted, guys.
Walter Brokx December 3rd, 2010 11:16 AM
And maybe you didn't see my own doubts about that advice?
Maybe there is a way to compare the used firmware and a fresh download without touching the camera?
If you want to find a solution you'll have to think of all possible causes and find a way to eliminate them from the list.
Maybe it was indeed the battery, or the connection to the battery.
James Clarke December 4th, 2010 07:07 AM
I suspect your cam may be overheating this was an issue with some ex1's a while back
Piotr Wozniacki December 4th, 2010 07:24 AM
No, it's not. The reboots/switch off's completely random, very rare, and without any obvious reasons.
Looks like some intermittent loss of contact somewhere. But - even with the warranty still valid - I don't want Sony to put my camera apart, and perhaps replace parts that are working perfectly well for me (like the lens, which is sharp, has virtually no CA, and a very smooth zoom capability - even at the lowest speeds).
Vincent Oliver December 4th, 2010 08:18 AM
Try cleaning the battery contacts in the camera. I had a similar problem with a Nikon camera and looking at the contacts they had a light film coating (no pun intended). Have you used your camera in a humid environment recently?
Piotr Wozniacki December 4th, 2010 08:53 AM
It also happened on DC-in, so it's NOT the battery contacts.
And no - my camera's never been exposed to much humidity, or salty water...
Dean Sensui December 4th, 2010 06:51 PM
Piotr... If the problem persists, then you might want to take the camera in before the warranty expires.
Although, as you said, the camera's other functions are just fine. The big problem is that it quits unexpectedly. One day you'll find yourself shooting a once-in-a-lifetime event, and your camera is going to shut down just as the most important moment happens.
Lou Bruno December 5th, 2010 07:54 PM
It is your power supply unit within the camera.
Andrea Fantasia March 20th, 2014 07:15 AM
Re: EX1 shuts down or reboots by itself!
Hi, I have the same identical problem.
Have you discovered how to fix it?
Best,
Andrea
Dave Morrison March 24th, 2014 09:24 PM
I also posted this in another thread, but if I barely touch or wiggle the power switch on my EX1, it will switch off and reboot. For now, I avoid touching the power switch when I'm rolling, but it's going to bite me one of these days. I just don't have the money for repairs right now.
