-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Upgrading from original EX-1. Cam suggestions? (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/486091-upgrading-original-ex-1-cam-suggestions.html)
Charles Dasher October 13th, 2010 02:56 PM
I am ready to turn over my Ex-1. I have had this since the early release of the camera. It has been my workhorse for everything from WEB, DVD, and some broadcast work.
I have a 7D set-up but still turn to the EX-1 for my main production camera.
The EX-1 is getting on in hours and I am thinking of replacing it with an EX-1R, EX-3 or.......?????
I travel quite a bit and enjoy keeping the EX-1 in a Porter Case for hassle free carry-on. Is easy carry-on possible with the EX-3 form factor?
Any news on upcoming cam releases that I should be aware of? Rumors?
Thanks for any info.
Dasher
Dean Harrington October 13th, 2010 04:15 PM
Ex 3 ...
What I have done as carry-on with the EX3 is take the lens off (one has to make-shift plastic back lens covers and exposed front cam cover ... tupperware lids will do) and set lens/cam side by side in a small bag.
This solves the carry-on problem. I have a shoulder brace and bracket attachment for a NanoFlash so the camera is a bit longer than without. I have been able to get a kata 502 on international planes out of Tokyo but I dare not bring this to the U.S.! I've heard of problems especially on domestic flights ... so, a smaller bag is necessary. In my view the EX3 is an idea cam especially when complimented by a NanoFlash or the AJA KiPro Mini for 4.2.2 acquisition. This makes the cam more viable in a broadcast media format. The PMW-350 is ideal but a large form camera and that has it's own problems along with a being greater investment.
Kevin Spahr October 13th, 2010 05:54 PM
Dean, which bag do you use when you separate the lens from the camera? I've been thinking of doing that for carry on because to get out of town I have to fly on a 25 seat plane sometimes.
Dean Harrington October 13th, 2010 08:31 PM
case ...
I have a hard carry-on case ... Japanese model but similar to a Pelican 1510 No Foam Carry On Watertight Hard Case. Look into these cases if you don't need a back-pack. Get some foam and organize the insides as you see fit.
Buba Kastorski October 14th, 2010 07:39 AM
I am in the same situation, i love my EX1, but my B and C cams are 1D and 5D, and on the same timeline they look a bit differ from EX, I keep EX1 for steadicam and sound, but would love to replace it with larger sensor;
let's just wait till NAB, after that we'll see if it needs to be upgraded:)
Tim Polster October 14th, 2010 11:28 AM
Charles, I would not see the point in an EX-1R upgrade unless you need SD. The two cameras are very close. With solid state I do not know what would be considered a lot of hours on one of these cameras but I would guess it is a lot longer than tape based cameras.
It sounds like you are wanting a visual upgrade to your image quality in the EX-1 size package. I do not think it exists. I am left wanting with the 5D & especially 7D for color. The EX-1 or other video cameras just look better when I get them on the timeline.
Until this Scarlet appears with 2/3" imagers I do not see anything out there that is really the same form factor and an upgrade to the EX-1.
Mikel Arturo October 14th, 2010 12:09 PM
I bet for a EX1-R... with 4:2:2 codec.
This combo will be amazing.
Sony, open 4:2:2 recording for the masses!
Charles Dasher October 14th, 2010 02:06 PM
I appreciate the feedback.
Glen Vandermolen October 14th, 2010 02:42 PM
Have you checked out the Canon XF300/305 cameras? They're a little bigger than the EX1 and you won't need a Nanoflash - they already record onto cheaper CF cards at 50mbps, 4:2:2 color. The images from the camera look great.
I've worked with the EX3 and that's also a terrific camera. It'd be a tough choice between the two, but the broadcast-quality codec from the XFs might move me in that direction.
BTW, what's wrong with the EX1? I would think it'd still be a viable camera.
Jonathan Shaw October 19th, 2010 12:33 AM
I wouldn't upgrade as yet, the Panny Af100 will be inetresting, the new Sony 35mm digi cam could be good too. Ex1r isn't a massive upgrade and the Canon's are great but they still have 1/3 " chips. I would invest in a Nano or Ninja.
Paul Cronin October 21st, 2010 08:03 AM
Hi Charles hope all is well. Lots of sailing in your area this winter, maybe we can catch up?
I have been in the same situation having 2-EX1’s and making money. Then I was forced to upgrade due to a couple of contracts and went Red One, PMW-350, then to the PDW-F800 it was expensive. I have now sold all of them and am back to the EX1/Nano for now. Some of them made money and other did not. My suggestion is to wait and keep using your EX1/Nano combo. Things are happening fast with camera companies chasing each other and the gear is getting cheaper. This is thanks to Red and Canon pushing the slow movers Panasonic and Sony. I see no reason to buy expensive gear at this time, unless a client demands it and pays the difference in your rate.
I bet by NAB or sooner we will see a few nice cameras with interchangeable lens that will be very cost effective and will compete with and improve upon the Panasonic AF100. But don’t sell your Nano!
The new Canon XF300 is not an upgrade from the EX from my viewing and a short hands on side-by-side with EX. If you did not own a EX the Canon XF is an excellent choice but it does not make sense to sell the EX and go with the Canon XF.
And who knows maybe Red or Canon might even have a new cameras, Sony will not let Panasonic run with the AF with out competition. Either way my advice is keep-making money with your current gear and wait till the new camera you see will make MORE money for you then your existing gear. This advice is based my own mistakes and I hope it helps.
Ronnie Martin December 30th, 2010 01:53 PM
I have owned both the Ex-1 the Ex-1R, the EX-3 and now the pmw 320. The most bang for the buck is the Ex-1R. BTW the pelican 1510 with custom interior for the Ex-1 will not fit the Ex-1R. I ordered a case from Cruzer Cases which was a 1510 with an insert for the Ex-1' The way is was configured you would have to take off the eye cup and the lens cover and then make a modification in the insert to allow the extra shoe the Ex-1R has on the handle. Side by side the 1 and the R seem identical. However, the cutout was way to tight for the R. I really like the cruzer carry on case but reluctantly sent it back. What I want is a similar case as the 1510 with a cutout for the Ex-1R that allows the camera to still have the lens hood and eye cup on the camera.
I guess the only way to get this is to get one of the cases with the "puck out " foam and make my own.
One problem with the "pluck out foam" make sure it is closed cell foam. The regular stuff emits a gas when it gets hot and a smoky film will appear on the outside and inside of your lens. Have you ever noticed a film on the inside of you car windows or dash board? That is the same process.
If you locate a hard case similar to the pelican 1510 that will fit the EX-1R please let us know.
One other thing.... since these new cameras have no tape mechanism the life of the Ex-1 should be many times longer than the tape cameras. I would consider sending the Ex-1 to Sony and have it cleaned and the firmware updated to the latest version. In the past we always thought about 200-400 hours on the heads was getting along in time. However, with the new solid state cameras they are really computers and should last thousands of hours.
Good luck
Ronnie
Brett Sherman January 2nd, 2011 06:46 PM
I'd keep the EX-1 and wait to see what happens with the next generation of cameras. It looks like we are going to larger single sensors. To me the EX1R is very incremental and not worth the money in my opinion if you already have the EX1.
Vincent Oliver January 3rd, 2011 04:25 AM
In short the EX1 is a great camera, the EX3 is a better option especially if you want to add extra lenses (nikkors with an Adaptimax or Mike Tapas adapter).
Many photographers and videographers look for something better, but never explore the full potential of what they already have.
Sverker Hahn January 3rd, 2011 05:49 AM
I have the EX1 but want the option of exchangeable lenses.
One alternative is EX3 with the addition of NanoFlash.
Another alternative is a Red Scarlet or Red Epic-S.
Different prices and EX3 is here now. The Reds maybe turn up at NAB.
Waiting or not waiting - that is the question ...
Paul Cronin January 3rd, 2011 07:23 AM
Vincent that is the truth.
Single chip camera is a very different beast then the EX1/3. if you need SDOF which in my opinion is very over used you should go to a single chip. But most shooting really needs DDOF and the EX line is great as is the Panasonic line.
Charles have you made a move? Are you going to any of the Formula regattas?
Dean Harrington January 3rd, 2011 07:31 AM
Ex3 ...
I understand your concern about cameras. I look at the matter as though different cameras serve different purposes. The EX3 is an excellent choice for an all around camera ... especially when it's coupled with a nanoflash, Ki Pro mini or any other 4.2.2 recorder. Now, if you want a camera that will make good commecials or films of any kind ... cannot speak for other types of output yet ... them a large sensor camera would be my first choice ... an alexia or a RED but I can't see how I can pay for such a camera yet. Many are in the same situation here. Until the dust settles ... I'd say sometime in summer or fall ... an EX3 is still the best choice for a 1/2 sensor camera! If you don't need to buy now ... wait.
Sverker Hahn January 3rd, 2011 04:02 PM
The Red Scarlet with its 2/3" sensor is not giving such a shallow depth of field as the Alexa or F3. And the price? Nobody can be sure, but Red Scarlet users-to-be are discussing around $10k for a basic setup. Not so much more than the EX3 and then you get a much better camera.
Craig Seeman January 3rd, 2011 05:02 PM
RED Scarlet recent prototype showings seem to be a fixed lens camera.
You really must define your target before you purchase the camera. I guess if you want a 2/3" camera at a reasonable price the Scarlet might fit the bill but the 1/2" EX3 is going to give you more lens flexibility.
I'm hearing about RED Epic-S at $12K and maybe that'll be a SDOF interchangeable lens camera. At that price range one may have to do a comparison between it and the Sony F3 for a few $K more.
Alternately there's the Panasonic AF-100 and Sony has NXCAM SDOF camera coming later this year.
I'd wait on buying anything unless you have a very short ROI on the purchase.
Sverker Hahn January 4th, 2011 03:53 PM
The Red Scarlet comes in two flavours, both 2/3":
- Scarlet Fixed with a non-changable 8x zoom lens.
- Scarlet Cinema with options to use PL-mounted lenses, Nikon, Canon and many other brands of lenses.
The owners of Red One get the first Scarlets - and after them the rest of us. I have little hope to buy one even this year, at least that is what I fear. Therefore the best choice for me would be a second-hand EX3 with a NanoFlash, with the Adaptimax for my old and coming Nikon lenses. The EXs are great cameras ...
