-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   For the life of me I can not get the little remote to work with my new EX3 (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/484513-life-me-i-can-not-get-little-remote-work-my-new-ex3.html)
Jerry Porter September 9th, 2010 12:33 PM
Just like the title says... I can't seem to get the IR remote to work with my new EX3. I go into the menus on both sides (cam and media) and turn it on. Try to use it and no go, go back and look in the menu and it has turned itself off again. What am I missing here??
Andrew Stone September 9th, 2010 02:34 PM
Have you removed the little clear plastic flap that separates the battery from one of the contacts inside the remote?
If it is still there, you should see a little flap waving around the edge of the battery compartment door.
Khoi Pham September 9th, 2010 02:44 PM
Turn on your camera and point your remote at the lens and push any button and look at the lcd of your camera, if you don't see a light then the remote is not sending out a signal, this way you can narrow it down to which one is mess up, (camera can see the infrared but not our eyes)
Eugene J. Kulak September 9th, 2010 04:32 PM
The IR remote will default to off every time you turn the camera off.
Jerry Porter September 9th, 2010 05:13 PM
That is the problem. Why would they do that??? Turn it on, change it to media and then it's off again... I think that is a little silly on Sony's part.
Andy Shipsides September 9th, 2010 09:44 PM
Yea it is very silly, perhaps a power saving feature. You can assign a button to turn on the IR function if you are using it often.
Vincent Oliver September 10th, 2010 01:29 AM
I tried the remote several times nut never had much luck making it work unless I stand directly in front of the camera pointing the remote a few inches from the camera body. Then if the weather is right, no wind, snow, hurricanes or rain, it might just work. I now just use the first finger on my right hand as a remote.
