-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   shot transition won't memorize focus? (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/481525-shot-transition-wont-memorize-focus.html)
Malcolm Hamilton July 7th, 2010 02:06 PM
Hi there,
With Shot Transition in 'Store' mode, I set focus on a close-up of some oranges in a bowl, press the 'A' button, and then zoom out a bit to some candlesticks, refocus and press the 'B' button. Then switch to 'Check' mode, press the A button, and the camera zooms back in on the oranges, but doesn't go back to the proper focus.
Only the shot B focus is memorized.
Am I missing something?
Thanks, Malcolm
Malcolm Hamilton July 7th, 2010 02:19 PM
Finally realized that I have to be in auto for focus to do this.
Malcolm
David C. Williams July 7th, 2010 08:16 PM
I don't think you need auto switched on, but you do need the focus ring slid forward.
Serena Steuart July 7th, 2010 11:46 PM
Correct. Focus ring must be disengaged from full manual.
Malcolm Hamilton July 8th, 2010 05:47 AM
Yes, thank you both — focus ring slid forward is the right way to put it, and shot transition now works.
Funny thing is that for me, though, it only works if I'm in "time" mode.
"speed" mode doesn't work. Is there something else that has to be done?
regards, Malcolm
Serena Steuart July 9th, 2010 01:15 AM
Speed/time: I don't think so. I just swap between them as necessary. I work in full manual (other than the focus ring thing).
