Hot-pluggable zoom controller for EX1
Hi,
I am actually searching for a good zoom controller for the EX1. As I have to switch very often between tripod and handheld shots, it would be important for me to be able to connect and disconnect the zoom controller without having to switch the EX1 off and on. Can anyone having zoom controllers tell me which one you have and if this is working with yours ? Thanks in advance, Bye, David Arendt |
I have a Zoe controller and it hot plugs in and out no problem.
I can't see any reason why all the EX1 controllers wouldn't hot plug. They are analogue devices and not at all like Lanc controllers. (The only problem I get sometimes is when powering up the camera with the controller attached and the zoom control is being pressed slightly in one direction. It aligns or centres to this position so you can't zoom properly in one direction. I've not explained that very well have I?) |
This is the one I have and I absolutely love it. There are a few reasons I chose this model over the cheaper one (VZ-Rock-EX): 1) this is all metal whereas the cheaper model is plastic and users have reported the plastic breaking when clamped too tightly; 2) it has a dial controlling the speed, and you can adjust the speed during the zoom, which allows for perfect feathered zooms.
http://www.bhphotovideo.com/c/product/543232-REG/VariZoom_VZ_PRO_EX_VZ_Pro_EX_Comfort_Grip_Zoom_Controller.html Another thought - the Varizoom VZ-Rock-EX is commonly used on the handle of shoulder mounts. |
Thanks. I have finally decided to order the Manfrotto 521EX from Bhphotovideo as I use a Manfrotto 503 head and it had relatively good comments. On the Varizoom ones, opinions seemed to be divided, some better ones, some worse ones. When I have tested it, I will report back.
David I just sent you an email from this forum. I have a Manfrotto 521EX that I am not using.
-Andrew |
