-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   EX3 vs EX1r as 2nd Camera (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/479063-ex3-vs-ex1r-2nd-camera.html)
Steve Kalle May 20th, 2010 01:38 PM
I have an EX1 and need to rent another camera again. This time, I am considering the EX3 so I can keep both cameras in sync; however, the EX3 costs more to rent. With the EX1 I rented, I transferred the settings info from my EX1, but I read somewhere that the EX3 is slightly different; so, it doesn't allow the settings xfer. Is this true?
Is there any benefit of using an EX3 versus an EX1 or EX1r? If I rent the EX3, I will most likely use it as my main camera for this concert-type event with my Varizoom Pro zoom controller, which I assume works with the EX3.
Bruce Rawlings May 20th, 2010 02:38 PM
The EX1 suf file will not work in the EX3 but you can tap your settings into the EX3 AFIK.
Hiram Yates May 20th, 2010 06:36 PM
Bruce is right, I've used an EX3 several times as a second and manually adjusted picture profile setting to match and saw no difference in post.
