-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   PMW-350 Default Scene File? (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/478011-pmw-350-default-scene-file.html)
Ron Wilk May 2nd, 2010 02:45 PM
I've had my 350 barely 2 weeks and, so far, I am very pleased with it. But due to the abominable user's manual I keep generating new questions, many of which, thankfully, have already been addressed on this forum. I have not found an answer, however, to the following question:
At initialization (when the camera is first turned on) which, if any, scene file is it referencing? I have noticed that at this stage, none of the scene file boxes are checked and since I have yet to alter or add to those in the camera's memory, the only scene file that appears to exist natively is "standard," but its box is not checked at startup.
Secondly, I wonder if anyone knows whether it would technically feasible, with some future firmware update, to allow for the retention in memory of the last scene file used?
Doug Jensen May 2nd, 2010 04:08 PM
Whatever scene file or paint settings that were in use when you powered down remain in effect when you turn the camera back on. The fact that the box is not marked when you power up is just a software flaw.
Vincent Rozenberg May 2nd, 2010 04:53 PM
Yep, that's how it works on the PDW F350 and the 530/510 as well.
Ron Wilk May 2nd, 2010 06:05 PM
Thank you for the explanation.
Alister Chapman May 3rd, 2010 01:56 AM
The default scene file is the "Standard" scene file. As has been said the last used scene file is remembered when you turn the camera on. You can adjust the default "Standard" scene file settings that are stored in the cameras memory by adjusting the settings and then saving them as a reference file in the cameras memory. Whenever you choose the "standard" scene file the reference file settings will be used. To revert to the factory default "standard" settings you would need to use the "reference" "clear" option.
Tom Roper May 3rd, 2010 10:05 AM
Unless you recall a scene file, it uses the current working memory when powering up. It is assumed that you could have modified a setting from the previous session, therefore no box would be checked.
Doug Jensen May 3rd, 2010 10:37 AM
Sorry Tom, that is incorrect. Although I can see the logic of what you are saying, it is a software flaw.
The F800/700 had the same problem until last month's V1.63 firmware update that fixed it. Now when you turn the camera on, it always shows whichever scene file was selected last -- regardless of whether any of the paint settings of that file have been modified since the last time it was recalled. I suspect the same change will made in a future 350 firmware update, and that is why it is a bug, not a feature.
The problem with all these cameras is that you can never be sure if something has been changed since the scene file was last recalled. Not only when you turn the camera on, but even before it has been turned off.
I've been lobbying for Sony to add a "*" symbol next to the name of the current scene file immediately when any one of the dozens of paint menus get changed. That way you'll always be able to tell at a glance whether the camera is using the original scene file settings you think it is, or if at least one setting has been changed.
I hope that makes sense the way I have explained it. It's a feature I'd sure like to see.
Tom Roper May 3rd, 2010 11:14 AM
That seems like it could be a flaw worse than the one they are fixing. If you go to the scene file menu to inquire which scene file is currently selected, it would be misleading if there is a check mark next to a file that does not match what is actually set.
The asterisk sounds like a good idea.
For now, when I want to store a change to a scene file, the first thing I do is recall the scene file before making the change, so as not to inadvertently store changes I don't want along with the changes I do.
Doug Jensen May 3rd, 2010 11:24 AM
Tom, I agree with you 100% and I do the same thing.
Ron Wilk May 3rd, 2010 02:54 PM
Hi Tom:
After you recall the scene file, by which I assume you mean that you are loading it into the camera's memory, and make whatever changes you deem necessary, are you saving it under a different name in order to preserve the original? Are you saving to camera memory or to an SxS card?
Tom Roper May 3rd, 2010 03:11 PM
I save to both memory and card. I'm satisfied with my scene files. I will recall a scene file to put the camera into a known state, and if I thereafter make situational adjustments to it, usually very minor, I do not save them.
But when I was saving them, I would overwrite the same scene file.
Ron Wilk May 3rd, 2010 05:05 PM
Thank you.
