AB charger to EX3 instead of battery
...for AB dionic / EX3 users out there:
is it safe to use the titan-charger (attached to the QR-EX3 plate) to power the camera instead of the battery ?? (with an AC power outlet near the camera, off course...) any comments would be greatly apreciated.... regards |
I do it, no problems. In fact I power two EX cameras with one Titan unit for a 3D rig.
Enrique you probably know this but worth mentioning anyway... On the rear panel of the Titan charger is a 4pin female XLR power outlet. You can switch the charger over to put power through this outlet.
You would obviously need a 4 pin XLR male to an EIAJ-04 connector that the EX3 utilizes to power this way. I know Vortex Media sells a reasonable priced cable that fits the bill. |
I would be inclined to have a battery attached to the charger in the hope of soaking up any inrush surges unless there is also a hard switch between the charger and camera. Those currents could be a bit savage if you experience a series of flickers on mains power that happen sometimes just before a blackout.
I have used a Titan on back of a SI2K recorder unit which has an AB Gold dock and observed a distinct surge in the touch screen blue "power-on" display when mains was switched on. The SI2K is hard switched, the monitor was non-genuine and was not switched through the SI2K. The EX1 is soft-switched, thus cannot be isolated from inrush currents unless a hard switch is introduced between camera and charger. It may not endure inrush currents forever. The EX3 might be soft-switched too, however I do not know this. Anton Bauer may have more information to give you if you were to ask. This is only my unproven observation and theory on the matter and I may be propogating misinformation here. The Titan has been a compact and convenient "international" mains power source for the SI2K so far but it does get a bit hot on our mains out here 240vAC 50Hz. |
thank you all... AB just let me know that the Titan (or Tandem which is the new version) is safe to use with the EX3 as external power supply...
regards |
