-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   XDCAM EX-3 SD 16 X 9 output (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/476698-xdcam-ex-3-sd-16-x-9-output.html)
Jim Watt April 12th, 2010 06:46 PM
I see no option for a 16 x 9 output in SD through the SDI or component out connections. I see three choices 1. Squeeze; 2. Letterbox; or 3. Cropped. Am I missing something? When I feed the "squeeze" picture into a 16 x 9 monitor it appears to be a 16 x 9 picture, though when i record this output on a Nano Flash in SD the format in FCP says it's 720 x 486. It does however look fine on a timeline if I let FCP select the timeline format.
thx...jw
Producer/DP, HD series, "Discoveries...America", "Discoveries...Ireland", "Discoveries...Spain",
"Discoveries...Argentina", Discoveries...India", "Discoveries...Asia", "Disc
Bruce Rawlings April 13th, 2010 02:07 AM
Surely all is Ok. Your SD file contains the anamorphic picture at the correct SD size.
