-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   EX1+Mattebox+Nano Too Heavy for Sachtler FSB 6? (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/472869-ex1-mattebox-nano-too-heavy-sachtler-fsb-6-a.html)
Steve Kalle February 14th, 2010 12:49 PM
I have the Sachtler FSB 6 and EX1 and will buy the Nano (+ Swit battery), Arri MMB-1 mattebox and Olof's mounts.
Is this too much for the FSB 6?
And if I added my 2 Sony wireless receivers?
If I wanted to add a Manhattan 8.9" LCD?
EDIT: I will also be getting a 10lb teleprompter; so, what head would be a minimum for EX1, Nano+Swit, 1 wireless receiver & teleprompter?
Bruce Schultz February 15th, 2010 02:21 PM
I have loaded my FSB-6 head with an EX1, Arri Mattebox and Sennheiser wireless many times without feeling like it is in any way overloaded. I have a NanoFlash coming this week so I'll test that along with the rest, but my guess is that the FSB-6 can handle it all very easily.
Chad Johnson February 15th, 2010 05:52 PM
The FSB8 would be better suited than the FSB6.
Walter Brokx February 16th, 2010 04:02 AM
Just a quick search gives you the data about maximum payloads:
sachtler: Fluid heads
It says the FSB 6 can have 6kg (13,2 lbs). Now you know this, you can weigh your set or do the math by calculating the weight of all elements.
Like mentioned before: the FSB 8 might be a safer choice. Just make sure the tripod can handle the load as well.
