-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Detail setting for a "filmic" look. (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/472308-detail-setting-filmic-look.html)
William Graydon February 5th, 2010 12:54 PM
At one point Simon Wyndham commented in the picture profile thread that adjusting the detail setting to -20 with a frequency at +40 was a way to achieve a "filmic" look I have it set to -15 and +40 But I would like to know if this still holds true?
I have looked through the threads and have found only few bits and pieces of info on the detail setting and how it can give my EX1R that "filmic" look I have wanted.
Thanks in advance.
Daniel Epstein February 5th, 2010 04:06 PM
William,
There is no one setting which will give you a "filmic" look with a nonfilm camera. People play with the detail settings to avoid artificial looking sharpness which is one aspect of the difference between video and film. Sometimes people go too far and everything looks too soft. Frame rates like 24P, appropriate shutter speeds and different gamma settings have a lot to do with the film look on a video camera. Filters in post can make a huge difference as well.
One of the biggest differences to me is the lack of movement in the grain of a video camera which is why adapters with spinning ground glass and 35mm lenses look more film like to me. Depending on the shoot just using 24P (which I like),turning down the detail (my taste is a little on the high side compared to the no detail crowd but still low) using filmlike gammas can get you closer to a look.
While Simon's settings may get you in the ballpark and you might decide he hit it right on the head it is okay if you use his settings as a starting point for your own exploration. The toughest thing is how do you evaluate what you are getting? What screen size do you use etc.
William Graydon February 5th, 2010 04:57 PM
Thank you very much Daniel your advice was spot on and that's exactly what I will do use it as a foundation to expirement with different looks.
Thanks again for your advice.
Dave Chalmers February 6th, 2010 03:21 AM
Standard BBC EX1/EX3 setup
Hi there,
You might have found this but the BBC has a 'recommended' setup for the EX1/3 which includes a suggestion for the detail setting.
BBC - R&D - Publications - WHP034 - Addendum 27
Just to be clear when this document talks about 'film' and 'video' it is specifically talking about differences in exposure and dynamic range settings and NOT anything to do with 24p or temporal settings to match film.
It recommends the 'film' setting for shots that WILL be graded and therefore preserves highlights and shadows, and the 'video' setting is for shots that will not be graded and mus t maximise the dynamic range in-camera.
Hope that helps.
Dave
William Graydon February 6th, 2010 09:43 AM
Thanks Dave. That was also very informative and helpful. I had been looking for something like that.
Brian Barkley February 6th, 2010 11:52 AM
My best luck with a film look is in Adobe Premiere ... they have a great film look effect. By adding just a tiny bit of grain usually does the trick. I'm sure that Final Cut would have that as well.
Peyton Quinn February 6th, 2010 01:34 PM
HD video to 35 mm film transfer
<<One of the biggest differences to me is the lack of movement in the grain of a video camera which is why adapters with spinning ground glass and 35mm lenses look more film like to me. Depending on the shoot just using 24P (which I like),turning down the detail (my taste is a little on the high side compared to the no detail crowd but still low) using filmlike gammas can get you closer to a look.>>
Very usefull information sir, it confirms my feelings and research here too. The "look" is quite subjective I have observed, Younger people are conditioned to see a give "look" diffrently from adults for example.
As a Dr. of psychology I have done experiments in this and can tell you without question this is statistically true. We can't know exactly what we are measureing but we do know we are measureing the same thing each time and there is a statistically signifcant result. I will publish this research in perhaps another year to 16 months when I finish the trials etc.
Lenses also seem to make a signifcant diference in getting a reported more "film look".
The sony HVR Z7U takes cinematic lenses and gets a more film look to many people's eyes, I wonder how it would be percieved if footage from this camera was transfered to 35mm film. Does anybody know or seen this result, and with nay HD camera footage (though the Sony HVR Z7U) is my primary intrest here as it is the control.
Some effects like the shaky camera looks "film" like to some younger people, but to some adults it gives them nausea. Brain wiring is not fully formed in person unitl about age 20. This is determines and arguments the decoding in the visual cortex. Hence, younger people exposed to many different media as they grew up do see things on a screen diffrently than older people.
In fact, though the sample space here is too small to make a conclusion, it appears that the younger people (18 to 21 or 22) do not identify HD video that has been "proceesed" for a more "film look" quite as quickly as do older people. This is because the older people's 'neural nets' were formed in a "film only" enviornment when they were young.
When I see a program of TV, I know at once if it was shot in 16mm, 35mm film or HD video and often even what camera might have been used. But it surprised me at first how a good number of people can not even immediately discriminate film for 'processed video' made to look like film. I mean see it "right away' or immediattely.
Now I have a question: Has anyone seen the result of transfering 24 P, HD video to 35 mm film? What does it look like to you and what is your generational age?
Does the result appear more like it was shot orginally on film, and perhaps 16 mm film? If you can answer please post it here but also could you email your reply to me Dr Quinn at peytonq1@gmail.com
By the way, I am healthy 60 nowand on my "bucket list" is to shoot a feature film. I have actually worked on two major Hollywierd productions. I even wrote part of the script for Road House with the ,late Pat Swazey. My life has been not the ordinary one, and I did not desire an ordinanry one either. I have few regrets really, just a few things I wnat to get done before I 'chek out'.
I will shot my feature with HD video aquistition. Again, what do you good people think of the about the Sony HVR Z7U? then transfering it to 35mm ? ( I know the cost of transfer is high but that's still less expensive than shooting in film) Thak you all! Peace be with you all and thnak you for your replies.
Peyton
Geoff Addis February 6th, 2010 02:18 PM
Thought for the day:
If HD video had been invented before 24fps film, would there be so much obsession in trying to achieve a 'film look'? Why do some prefer to see jerky movement and grain? Is this the visual equivalent to those who swear that the sound quality of a vinyl disc is better than that of the cd, even though both will have been recorded and mastered digitally, do we just like visual and aural noise or does its presence add to the illusion?
Brian Barkley February 6th, 2010 04:14 PM
Geoff asks a good question, and the answer is "it is just a matter of opinion".
I think it's what the public has become use to. When shooting a dramatic theatrical production with actors, the "video look" might be compared to a "soap opera look" on TV.
That's all any of this "stuff" is . . only opinion. Lighting, camerawork, etc. is a matter of opinion. If you've seen "Up In The Air", the lighting and camerawork, and even the directing, is not at all flashy ... actually somewhot mundane, but that's the effect they wanted in telling their story.
Shaughan Flynn February 6th, 2010 04:59 PM
I blogged about this back in '08: B-Scene Films: Cinema is lies told at 24fps
I got an insane amount of hate for that blog post too...
Ivan Gomez Villafane February 6th, 2010 10:56 PM
By the way, I think 24p looks much more real than 60p.
Just move your head around as if you were a camera, without really focusing on anything: can you perceive the "stuttering", the lack of smoothness? Maybe this is a very silly comparison, but it makes quite a lot of sense to me.
It is very appreciable with moving objects... go outside and see a bird pass by. OK.
Now watch it again, but move your head while always keeping the bird on the exact same place of your "frame". Can you perceive how the bird stays very clear and the rest is blurred out, just as like if you were following something while in 24p mode? You can't get that look with 60p...
Maybe 24p is a tad too few. Maybe 30p is better, I don't know. But I do know 60p looks awfully unreal to me when compared to 24p.
Just my personal thoughts...
Simon Wyndham February 7th, 2010 03:59 AM
This isn't strictly true, since Alan's detail settings for cameras are designed to replicate as close as the camera allows the way that film handles the different detail frequencies. Incorrect detail settings are one reason why people notice judder more with video than they do with film.
Piotr Wozniacki February 7th, 2010 06:04 AM
I second that; with the moving subject in perfect focus, but those high frequency details behind being soft enough, and those dark areas further crushed into black/softened with positive crispening - I can follow the subject with even relatively fast pans, and still get virtually judder-free picture.
William Graydon February 7th, 2010 09:25 AM
So Simon my question is would those detail settings that alan provided give me a more "film" look overall.
Detail -5
Frequency +30
Crispening -45
Piotr when you say positive crispening do you actually mean setting your crispening to a positive value?
I am simply trying to find some of the better settings out there in order to see which one works best for my taste.
Btw I am using Bill Ravens TC2 file with CG1, CG3, and CG4
Thank you for all the input thus far.
Piotr Wozniacki February 7th, 2010 09:52 AM
Exactly - this makes noise in dark areas less pronounced. Of course, along with details of those areas - there is no free lunch:)
For low-light situations, when all details I care for are those well lit, I send all the others (i.e. those in dark areas) into dark hell by crunching blacks (Cine1, or even Std1), and set crispening to +30.
Then I can also sharpen the bright detals by setting knee aperture level to positive values (like +30). You can also increase their color saturation...
Here is a good reading on this:
Sony | Micro Site - XDCAM EX
William Graydon February 7th, 2010 10:05 AM
oh alright I will have to experiment with crispening setting because I have yet to actually adjust it.
In relatively well lit situations what do you set the crispening at?
Also I dont know if your also using Bill's TC2 but i find it a necessity to have the zebra at 100% (I actually have it set to 98%) do you also? <--- sorry if a little off topic it just popped into my head.
Piotr Wozniacki February 8th, 2010 02:53 AM
At 0 (default) for film look, or -15 (sharper) for realistic, punchy video. The latter only when there are no large, shaded areas of a single color, like big walls etc. - as they are usually noisy !!!
