-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   PMW 350 Lens, low light, noise etc etc (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/470936-pmw-350-lens-low-light-noise-etc-etc.html)
Steve Phillipps January 24th, 2010 11:00 AM
Cool, 1/2 stop sounds more reasonable. I know vaguely the science behind (thanks to a previous post by Alister I think!), and always thought of it as present but minor, just enough to make it worth sticking at 0db unless there is a big reason why not, as there is on the Varicam as it's not as noiseless as the Sonys it seems (from personal observation and comments from others). Actually from my observations on Varicam and PDW700, the Varicam has dynamic range to burn and the 700 is ultra quiet. In fact is's amazing to hear that the PMW350 is even quieter.
Steve
Tom Roper January 24th, 2010 11:50 AM
I shoot the standard 709 gamma with knee but the issue I have with 0 db boils down to the fact that the benefit of -3db lower noise is evident in EVERY image (if slight), whereas the benefit of 1/2 stop more latitude will only be evident in high contrast scenes. Using the histogram in combination with 100% zebras gives me the tools to recognize when it would be beneficial to switch to 0 db for the extra latitude, or alternatively preserving the low noise of -3 db for the situations that do not.
Steve Phillipps January 24th, 2010 11:53 AM
Tom, I'm absolutely amazed at that. Especially taking into account the comments about how noise free the 350 is even at 6 or 9 db. I never had the slightest hint of noise at 0db in the PDW700 - and I do look!
A real surprising find.
Steve
Tom Roper January 24th, 2010 11:58 AM
I will qualify my statement then that the benefit of -3db 'in theory should be' evident in every scene. It's not my intent to mischaracterize or draw comparisons to the PDW700.
It's tough to see noise, it's tough to recognize 1/2 stop of latitude without equipment.
Do you understand my logic? If a scene only has 5 stops of latitude, why not -3 db, whether noise is visible or not?
Alister Chapman January 24th, 2010 01:05 PM
It's a valid point that if a scene has restricted latitude then negative gain will give a noise advantage. I guess I'm too used to shooting in challenging conditions and forget that some lucky people get to control their scenes :0)
I would not characterize the PDW-700 as noise free, it's certainly one of the least noisy cameras on the market, but there is still some noise.
Steve Phillipps January 24th, 2010 01:20 PM
I do understand and it is good logic. I guess coming from a film background I'm diehard in my view that video has terrible latitude and needs all the help it can get! They are a million times better than they used to be though of course. What if you low latitude scene suddenly has a flash of brightness (subject turns towards a light source maybe), I'd prefer to be safe re latitude - as long as there was no noticeable noise penalty (ie noticeable on screen rather than measurable).
Steve
