DVCAM AVI format
Hello,
I plan to buy very soon a EX1r and I have some questions. The SD recording mode : How Final Cut Pro can manage DV wrapped in avi files ? Thanks for you answers |
Yes, no problem. It will warn you that the AVI file is not optimum for performance but it edits just fine.
OK,
thanks for the answer |
try adjusting the quicktime preferances for video, they always look slimey here too.
in the QuickSlime player: Edit-Preferances-Quicktime preferances-video settings- try the Software only mode GDI. also use your (software) Scopes, beings everyones player and codec decoder can be set different, dont trust anything on a computer :-) everything on it is adjustable. there are other players that will play a quicktime on PC much better than quicktime itself does. |
Thanks, that has given the footage a bit of a lift
