EX1r S+Q selection
When using the S+Q button to select this mode of operation, is it normal to have to confirm the change using the select button in association with the on-screen display that asks 'Change S+Q Setting, Off>On (or On>Off), Execute of Cancel'?
My first attempt at using this mode resulted with the on-screen display stating 'cannot proceed'; this was despite neither the SD, Frame, Interval or Cache Recording modes being on. Restoring the camera to the factory setting resolved this problem, but I now have the above on-screen confirmation being requested. There is no mention of this in the handbook and I am a little concerned that there may be a problem. Geoff |
probably not a problem, so many ways it will not switch.
all the things you listed PLUS wont switch while recording, OR while the final recording is being buffered out to the Memory. wont switch while using the I-Link out to DV or HDV wont switch if in multiframe shutter modes Many changes in THAT cam seem to be trading up the processing power or chip or something for One thing at a time. complete mode switches are often asking for a Confirmation of thier setting [Execute] Yes dear , do it already. i have not found a way to stop the thing from asking, but i really doubt that the things it is asking about could magically just continue recording without stopping, so i didnt much care. |
Hi Marty,
You were spot on. The reason that the 'cannot proceed' message came on was indeed due to the fact that the I-Link was on. Thanks, geoff |
| All times are GMT -6. The time now is 09:06 AM. |
