Shooting PAL in Dallas......it worked
Well, last week I did a shoot here in Dallas for a New York based production company who are doing a documentary on capital punishment for Israeli TV. As we shot mostly outside I had no problems.....but we got several night shots and at one location at a store. The parking lot was lit up by a very large fluorescent light....I noticed in the VF that the picture was "fludering" or having a wave go through it....the question is: is this the flickering that the manual is talking about and if I put the flicker reduce..would it gotten rid of the problem?
the picture did not look bad at all and the producer says " I can live with it"....the rest of the night shots came out OK.... TIA |
In the camera menu, did you try to turn on "Flicker Reduce" in 60Hz Auto mode? That should have taken care of it.
Thierry. |
Thanks...but I will try that next time, as I got a email this morning and they will be back in January for some more shooting...and they said the video looks good.
thanks |
Bill,
You should try and set the shutter speed to 1/60 if shooting under Fluorescent lights when shooting Pal in the US. The flicker reduce might work but I also have seen it screw up stuff when left on. Not sure which EX cameras give you the 1/60 shutter speed from Sony in Pal . You might be able to use Clearscan if you can't set up a Shutter position. Yes you will lose some sensitivity but what can you do. |
I've tried the flicker reduction in the camera and it really did nothing much for my problem with off frequency fluros at all. I just lived with it, as it was only hitting the walls behind the performers it was quite a nice effect, kind of like reflections off water.
If I had to avoid the 50Hz/60Hz problem I'd be matching frame rates to local mains frequency. |
What Danielle said!
I shoot 25P in the US a lot and I always set my shutter to 1/60th to avoid the rolling band issue. It's simple and it works! |
| All times are GMT -6. The time now is 09:06 PM. |
