CBK-DV01 for EX1/3?
Hi all, I would find it useful if my EX1 and 3 could record standard definition for certain jobs. The new XDCAM EX 350 camcorder has an optional hardware option to enable this (CBK-DV01) which gives DVCAM recording. I know its a long shot but does anyone think or know whether this will work on the EX1/3 once the new firmware is released? Thanks in advance.
I suspect not because I think it requires the encoder chip to do that.
...why are so many people requesting SD for the EX cameras ?? ... with the latest NLEs I don´t see any advantage on having SD obsolete masters... in fact I see many advantages on having HD masters for producing SD material ..... it is like requesting 3 MP still cameras when you have cameras that give you 10 MP....
kind regards |
If you are delivering SD rushes to client being able to shoot in SD makes a lot of sense. I can't remember the last time I did an SD shoot but I'm sure ther are many that would like SD. I have the SD option on my PDW 700.
SD will never be available on the original EX1 or EX3. The EX1R has an extra encoder chip inside. It's one of the reasons why the 1R is slightly wider at the rear, to make space for the encoder. |
Would the HVR-MRC1 taking a feed through the Firewire work? That unit can convert to SD.
Might be worth looking into. -Garrett |
... well, I guess because I'm so happy with the SD-DVDs produced with my EX3 that I don´t see any reason to look for SD anymore... and I have my HD for web, or easy HDTV viewing through new solutions like the WD media player... in fact I don´t have a BluRay burner yet....
good luck |
What is your workflow for producing SD DVDs from HD footage?
Using Vegas 9pro & DVD arch 5 on PC workstations .... rendering from Vegas timeline (sometimes SD-wide timeline when mixing with DV-wide sources) to mpeg2 DVD arch template with BEST and Progressive settings (shooting progressive 1080 or 720, 30fps with the EX3) and VBR 2 pass .... I've obtained very nice looking DVDs that looks even better on LCD or plasma TVs....
regards |
I used mine just recently on a (yuck) 4x3 SD job. The edited DVD was projected onto a BIG 4x3 screen in front of 500 people in an auditorium and the results were GREAT. At the other end of the scale you get 422 colour space recording at ever increasing bit rates and a great range of other options as well. Up there with some of your best, long lasting investments you could make. |
Re: CBK-DV01 for EX1/3?
I have a Nanoflash bolted onto the back of my 350 and often deliver IMX50 to some clients. Its costs a bit more than the DVCam card but has opened more doors in the long run with the extra recording formats available.
Tim. |
The 320 also has the SD/DVCAM recording option which is what the news networks want for uploading to the satellite.
A BIG advantage of shooting in full HD when the final output is to be SD is that you are able to reframe or use stabilising software such as Mercalli to improve those shots which could have been better. Another advantage is that converting down to SD can get rid of a lot of video noise. Using software such as TMPEG can produce very good results as can the latest version of EDIUS. (I have just compared FCP X to DVD with both the above and it appears not so good)
Geoff |
