-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   battery drain on EX-3 (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/466945-battery-drain-ex-3-a.html)
Ed Kukla November 1st, 2009 04:35 PM
I was under the assumption that battery drain was an EX-1 issue. apparently not. My EX-3, bought in April, will drain the battery if left on the camera with the camera turned OFF.
Is there a fix for this (besides removing the battery)??
Andy Wilkinson November 1st, 2009 04:44 PM
Ed, Over how long a period of time did this battery drain happen?....I'm assuming not since April.... right!!!! ;-)
Mitchell Lewis November 1st, 2009 07:37 PM
I have the same problem with our EX3. I just remove the battery when I'm done. No big deal. I thought this was just a design issue? I'm guessing that if I left the battery on the camera for about 2 weeks the battery would be dead. That's just a guess though, I've never actually checked.
Alastair Traill November 2nd, 2009 01:58 AM
There is a warning in the manual (p 28) advising not to leave the the battery in place, even with the switch turned off, as there is a slow current discharge.
David Herman November 2nd, 2009 05:11 AM
I used to leave my battery on my ex3 without a problem. Now in the last month it has drained when left attached. Can't see I am doing anything different so I have begun to detach after I am done. Not a major pain but I wonder.
Ed Kukla November 2nd, 2009 10:20 AM
I notice significant drain overnight. Can't quantify it, but its not from full to dead. Maybe 20% of charge?
