Will Fujinon TV lens S14x7.3BRM fit on EX3?
I have a JVC DV500 1/2" camera sitting in the closet not doing much. Occasionally, I will still get a client who needs 4x3 SD footage and the JVC does a decent job especially compared with the slew of 1/3" chip cameras (DVX100a/b)
The lens with the JVC is a Fujinon tv lens s14x7.3brm-29. Does anyone know if the Fujinon can be mounted on the EX3? If so, what adapters are needed? If not, is there a list of 1/2" SD lens which would fit on the EX3? Thanks in advance for any info u care to share. Be well Rob |
Yes the lens will fit with the EX3 supplied adapter.
But why would you use it. I had an SD lens for a while on My EX3 while Sony was fixing (they just gave me a new one) my stock lens. The SD lens is really inferior in pic quality. The Stock EX3 lens is not a $30,000.00 HD lens but it is really good optically. |
thank u for sharing your thoughts. the fujinon is a wee bit longer on the tele end 81mm vs 102mm producing a narrower dof if that were important. anyone know of a list of "keeper" 1/2" sd lens that fit the ex3? again, thanks in advance be well rob |
Re: Will Fujinon TV lens S14x7.3BRM fit on EX3?
I am using a canon YH19x6.7KRS SY14 with the adapter Great lens F1.4 crisp glass. I am using on the PMW300 Glad I saved it from my old SD camera.
The lens you used on the JVC will NOT fit on the EX3 with the standard adapter.
The JVC / BTS (Philips) / Panasonic 1/2" cameras had a lens cable. The Sony 1/2" cameras had (and have) a lens mount with hotshoe/contacts built in. The mounts for both 1/2" mounts are different and not compatible. //EDIT: Wow. Didn't notice this was such an old thread. |
| All times are GMT -6. The time now is 10:55 AM. |
