Should I be able to play the MP4 in the BPAV folder?
Got a new camera and am trying to work out the details.
I'm cool with Log and Transfer in FCP but I want to be sure I am backing up properly. As a test, I popped the SxS into the express card slot, opened Clip Browser, and drug a couple clips down from the upper list view pane, into the lower list view pane of a folder I created on my desk top. Then, I went to the desktop and opened the folder. Sure enough there is now a BPAV folder. Inside that there is a CLPR folder, CUEUP.XML, MEDIAPRO.XML, and a TAKR folder. Inside the CLPR folder are folders with the same name as the clips I copied. Within each of those folders are a handful of files, one of which is an MP4. Should I be able to double click on that MP4 and watch the clip? Because when I do I get a error message saying: The Movie Could Not Be Opened. The Movie Contains Some Invalid Data." If thats not the way to do it, is there a way to visually confirm - and by that I mean watch the clips - that the files have saved to the hard drive properly from within the BPAV folder or is there another way to do it? B |
However, I think that check is unnecessary. I have transferred thousands of clips with Clip Browser and never had one get corrupted. If Clip Browser says the clips were transferred, it is safe to assume that the were done correctly. Knock on wood. |
try VLC
the VLC media player can play them back. at least, it works for me over here!
Just make sure that CRC is checked ON in the Clip Browser Preferences.
I just drag the BPAV folder into my scratch HD or other storage HD. Simple drag and drop. Never had a problem yet. Copy perfectly.
Brett did you purchase the EX-3? Always good to have another EX user in Miami. |
Thanks for all the responses. This was my suspicion.
Jon, I did indeed. Have come across a couple of your posts while doing searches, sounds like you're into some cool stuff. I'll shoot you an email and maybe we can catch up. B |
Sounds like the person who doesn't wear seat belts and says they've never had a car accident.
Maybe it's the motorcyclist who refuses to wear a helmet. Quote:
Craig,
Do you have a recomendation? What's your process for confirming that the footage has properly transfered? My concern is obviously in the field. Until I can scare up some more cash for more cards, I'm forced to dump the cards to a hard drive while shooting and then reformat the cards and shoot some more. This is client footage, so obviously making sure it's been properly stored to the hard drive is essential. B |
the only trouble with clip browser is that sometimes it has trouble copying clips or doesn't see them if anything odd happened while shooting, This has happened to me a number of times. It is a reliable way to copy what it does copy , but make sure that every shot is seen by clip browser and all the gigs on your card are copied. It will not always tell you when it fails to copy a shot.
Sometimes it will tell you it can't copy something that is useable and needs to be drag and dropped. I wish they would upgrade this program and fix the glitches. |
| All times are GMT -6. The time now is 07:40 PM. |
