transferring additional clips from same card
I transferred about a half hour worth of clips off a card using clip browser 2.5 on a MBP. I shot additional clips on the same card without erasing the first batch. Now I want to transfer only the second set of clips. "Copy all" does just that. I'd like to grab only the second set of clips and transfer all of them to the same folder as the first set of clips.
Thanks |
Highlight the clips you want to copy in Clip Browser, by Cmd-clicking them or dragging a marquee round them. Then drag the whole lot to the window for the destination folder.
I thought drag and drop avoided the CRC check?
Is drag and drop totally safe, using the error detection feature of the clip browser? |
Drag and drop is just a different interface to the same copy functionality (assuming you are dragging and dropping within Clip Browser, not finder). It will perform CRC checking if you have this set in preferences.
If you wish, you can highlight the clips you want to copy then use Edit>Copy, then select the destination pane and Edit>Paste |
