remote commander
How's your IR remote control working for you? Mine is working poorly. I bought a new battery and it still works poorly. I have to hold it directly in front of the camera to get it to work. That seems unacceptable.
Mine is exactly the same - have to be within about 3m of the camera - hardly seems worthwhile.
3 m is OK to me, it's the fact I have to be in front of the camera. VERY close doesn't matter if I'm not directly in line with the IR sensor at the onboard mic.
The remote for my EX3 produces a very erratic zoom if used closer than a couple of metres.
The sensor is located in front of the microphone and I found that if I place a reflector in front of the sensor I could control the camera from behind. All you need is a small piece of aluminium sheet bent so that the IR from the remote is reflected onto the sensor. I used a rubber band to hold the reflector in position. Also Infrared range extenders are available in either kit form or complete. These copy the signal produced by the remote and transmit to a second emitter. This can increase the range of the supplied remote and as the signal can be carried part of the way by wire, transmission can be achieved through walls etc. |
I thought the remote was mainly to be used by single guys in the bedroom? If I'm correct in my assumption, than using the remote in front of the camera is perfectly appropriate. (joke)
(Yes it's stupid that you can't use the remote from behind the camera. Someone whack Sony on the side of the head) |
3 Attachment(s)
Gentlemen,
Just make up a "IR Remote to Cam, by Fiberoptic cable Mod". Simple, cheap, and you can use the IR Remote "freehand", or attached to your Tri-Pod's Control Handle. For more Pics, ckeck my other Posts. I've made this setup for about 10 different Cams now, since 2000. Harold |
Harold,
I considered your fibre optic cable option but it seemed bulky as well as more work and cost than a simple reflector. It would also be something else to trip over. |
I never understood why Sony did not make this bluetooth?
Then you do not have to point the remote - it would work from any angle. I have a PS3 that uses a bluetooth remote and it is Sony, so they have the technology. |
Mine works sporadically. Stopped working altogether, new battery, still nothing, then after jiggering IR on/off multiple times, got it to work again . When it works, though, it does work from behind the camera.
| All times are GMT -6. The time now is 09:52 AM. |
