Warning on Flange Focus Adjust
I just got back from a shoot where the lens simply came off in my hand while shooting. I neglected to run the Auto FB ADJ right afterwards and a lot of my wides were soft. Sony's manual states that "repeated adjustment is not necessary as long as the same lens is used", but I think this should read " if you change or remove lens, run the Auto FB ADJ test".
I finally spotted the problem in the viewfinder and ran the test against a blank wall and it worked. Not quite sure why the lens popped off--the barrel release is not a snap-lock, rather just a pressure on the flange, and maybe the release lever got bumped when removing the camera from the bag and just took a while to work its way free. Hope this helps others avoid the problem. |
My lens came off my EX3 lat last year. Cause? In and out of my camera bag which caused the lens to work free of its housing. Glad I was holding on to the lens and body at the time as it was sitting on my shoulder.
As my lens has manual back focus, I refitted the lens and carried out flange focus immediately. All is good. |
Hi
I think Sony is mistaken in that instruction as well unless they have unbeknown to us modified the laws of physics with new alloys as it pertains to backfocus calibration. Backfocus should be calibrated any time a lens is mounted, there is change in ambient temperature of 5 degrees or more for an hour or more and before every shoot if the camera has traveled in a vehicle. A backfocus chart should be used whenever possible of course. |
Backfocus is useful if you intend zooming whilst shooting, for most shots you would set up the focus before shooting. In other words you will not be out of focus as long as the image in the viewfinder looks sharp.
Daniel, you are right in sating the backfocus should be set up correctly. However, at the wide setting of the lens there is a lot of depth of field which makes manual focus very difficult.
When on location it is not always practical to perform the backfocus routine, especially if you have the client, talent and other crew members waiting about. On some days I may do two, three or more lens changes. |
Yes, re-calibrate often, but also use your eyes to check the focus often. |
I was zooming in on every shot, getting focus, and then pulling back--nothing looked out of focus until I got back to my 42", and virtually every wide was soft. It was not noticeable in the viewfinder.
Howdy,
Assuming a professional lens with manual back focus adjustment, you can set back focus after every lens change in less than ten seconds by having a chart on the side and panning to it. True some clients don't have 10 seconds but as Daniel points out they may suddenly have it when the costs of missing critical focus is understood. My approach is brightness up, contrast down, peaking minimum. Others prefer a variation of the three. The only problem I see with repeating back focus is throwing off a calibrated viewfinder (VF focus and luminance). Iif you use a separate monitor that's solved. Using 800 or less lines on a small surface area for critical focus on a 1920 or 1440 image is not the same as using full resolution on a large viewing plane eg. a 20" broadcast engineering HD monitor. Even if you have full res on some theoretical small built-in LCD, the less the physical dimensions of a hi-res display the sharper the image and the less detectable focus. Web clips of footage on video sites from new small format cameras look so good because they're so small. Same footage on a viewer's 46" flatscreen or movie theater is a different experience. Considering DOF as a product of footcandles as well as focal length, a wide focal length can still have narrow DOF at full open iris and be quite plainly obvious to the eye in certain lighting situations and camera/lens combinations. I've seen this many times in broadcast jobs using jibs where after backfocus was calibrated things improved. Regards |
I take the point that a small LCD screen is not the optimum way for accurate focusing. However, short of taking a large monitor on location, we have no other choice. The whole point of the EX1/3 is that it is a portable unit.
Despite what messages I may be giving out, I do backfocus my gear often. I also use the magnify function and peaking to check for accurate focus. And yes, I admit that I also zoom in to my subject to focus and then zoom out again to shoot, in this case you do need to ensure the backfocus is set up correctly. |
The supplied EX3 lens doesn't have manual backfocus adjustment and my auto adjustment was so hard to calibrate I just took it to a service center and told them my footage was soft on the computer.
Seems to be ok now - I don't want to touch auto FB adjust again. The Fujinon lens should really have a manual FB adjust too. |
