Clipbrowser 2.5 Problem
I have got a problem with Clipbrowser 2.5.
Everytime I export clips as .mxf to a drive they are the correct size, when I import them to Liquid 7.2XE they are the correct size but they only play 9.4 seconds and the properties all say they are 9.4 seconds, every clip no matter what there original size is. I have gone back to Clipbrowser 2.0 and all is fine it imports the correct size and length of clip. Any ideas? |
I use Liquid XE and I've not had that problem. Version 2.5 has a couple of "flavors" of MXF export. Have you tried exporting a short clip with each of the MXF choices and then imported each to see if they all behave as you describe?
G'day Marc,
I have tried all ways, 50p, 50i, 1920, 720 still no good. In fact if I convert 50p every clip is 9.49 and if I convert 50i it's 9.15 when imported into XE. I have also noticed that if I use the checkbox convert to .mxf when copying automatically it does not work. Yet it works for my mate. I have unistalled, reinstalled redownloaded no go. I will just have to use version 2.0 |
| All times are GMT -6. The time now is 09:03 AM. |
