-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   focussing objects closer than 0.8m/2.6ft (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/165937-focussing-objects-closer-than-0-8m-2-6ft.html)
Thomas Diehl April 6th, 2009 03:52 AM
I am having trouble focussing objects that are closer than 0.8m/2.6ft. With the sony z1 it was no problem to zoom in and focus object as close as 0.1m. (the viewfinder also showed the distance correctly, the ex1/3-viewfinder does not go any further than just 1m). The macro mode of the ex1/3 does not help either. What can I do?
Alexander Kubalsky April 6th, 2009 09:21 AM
The EX1 doesnt focus closer than 80cm away as marked on the focus ring unless in macro mode. Put it in Macro mode by push the focus ring forward to auto focus and setting the macro mode switch. The macro works great on anything closer than 80cm.
Macro mode is automatically cancelled out if the focus ring is pulled back into full manual mode.
Thomas Diehl April 6th, 2009 09:39 AM
I've tried the macro mode. But as soon as I zoom in or out just a little bit or move the camera a bit - the image does not stay sharp.
Nick Wilson April 6th, 2009 09:48 AM
Macro mode makes no difference at full zoom, but as the lens is zoomed out its effect becomes apparent. Wide than about 46% the lens will focus on an object level with the front of the lens hood.
Buck Forester April 6th, 2009 10:00 AM
In macro mode I can pretty much put things right up against the lens and stay in focus. I'm confused when you say, "zoom in", because in macro mode I'm zoomed out, it's already so close. As said before, make sure you're in auto focus (focus ring pushed forward) and the macro mode is on.
Keith Moreau April 6th, 2009 11:58 AM
If you add diopters to the front of the lens you'll be able to zoom to 99 in Macro or Manual mode, allowing you to be farther away from the subject. I just got a achromatic +2 diopter (not inexpensive though) and it makes a big difference.
The problem with the EX1 'macro' mode is that because of the lens, the 1/2" chip, etc to get very small objects to be big in the frame you have to go wide in order to focus, and get very close, and even then the objects may not be big enough in the frame.
Thomas Diehl April 6th, 2009 01:17 PM
Keith, that's exactly what I meant. (couldn't describe it properly).
Thank you for your hint! - I'll try the achromatic +2 diopter!
Serena Steuart April 6th, 2009 10:51 PM
To say "wide" is a bit misleading. Macro works for focal lengths not greater than 25mm. Also it doesn't require auto focus. Put it in manual focus but with the focussing ring in the forward position.
Keith Moreau April 6th, 2009 11:26 PM
For what I've experienced, the minimum amount a subject I can get with the stock EX1 macro (Macro in Manual or Auto Mode) is about 6cm from edge to edge with a 45% zoom and a few centimeters from the lens.
With the diopter I can get a subject around 4cm edge to edge from about 25cm away with a 99% zoom. This helps me because I don't have to get so close to the subject which tends to block out it's light or disturb it as much as having my lens right up against it.
So, what I'm saying is that you an get really close with the EX1 macro, but it's really not that effective at extreme macro videography without some add ons.
Serena Steuart April 7th, 2009 01:04 AM
Agree on all points; I was only being particular about instructions for using macro.
Buck Forester April 7th, 2009 07:52 AM
Shows you how little I know about this stuff, ha! I always thought sliding the ring forward is "auto focus", or manual focus with assist (which to me seems the same thing because the way it "assists" is not always what I would've chosen).
Keith Moreau April 7th, 2009 08:55 AM
Yeah, you can get the AF/Manual mode (ring forward) to be pretty much manual by switching the auto/manual switch on the left side of the lens to 'manual' and turning off focus assist in the menu. I have the macro switch set on all the the time, that way I just do one thing to get into macro mode, push the ring forward.
