EX1 hard disk recording USB drive
I have to shoot over an extended period of time without the ability to access the camera.
Has anyone tested shooting with the ex1/ex3 using a USB expresscard with a USB hard disk plugged in? |
How long is extended?
I'v used two SDHC 32GB cards for nearly 4 hours of recording time with EX1 and firmware 1.11. Sony's USB hard drive is 60GB. The two SDHC cards total 64GB so I don't see the purpose to the hard drive. It's easier and cheaper to buy more SDHC cards than deal with a hard drive, powering it, potential shock issues that can result in data loss. |
I've found plugging in two of the Sony PHU-60K Hard drives totalling 120GB works well with just under 8 hours of record time. Not the cheapest method but it works very well (you can't overcrack the hard drive though).
An alternative would be to put a 32GB SxS or MxR with a 32GB SDHC Card and a PHU-60K which will total 92GB/6 hours. Not had any issues with the PHU-60K but do prefer using either the SxS and/or MxR if I had a choice, but like you I sometimes need to leave the camera and have to high capacity memory. |
24 hours
I need to record for 24 hours.
I was thinking that it might be possible to purchase an expresscard34 to USB 2 adapter, plug it into a hard disk drive and then have it show up the Sony's 60Gb hard disk shows up, but instead of 60Gb its 1.5Tb. Any ideas on this? |
Firewire and On Location
hmm... Why On Location vs. Final Cut 6.04? The 35mb is much nicer than the 25mb firewire option also. Are there benefits to On Location/Firewire over ioHD with FCP?
| All times are GMT -6. The time now is 05:59 AM. |
