-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   EX1 LCD has the white measles (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/136064-ex1-lcd-has-white-measles.html)
Charles Dasher October 14th, 2008 01:05 PM
Over the last couple of months my LCD has slowly been developing small white blotches when the screen is on. I saw one thread where a LCD had blotches that were viewable even when the camera was off. This is not the case for mine, they appear when the screen powers up. It started with one area and now there are several. Not sure if this is a dead pixel issue. The spots do not look like the dead pixels I had on my Sony Bravia TV I returned. They seem to have a softer edge around them.
I am planning on sending in the camera firmware updates and for this LCD problem. I have read Sony has a disclaimer on the LCD and I am wondering if will make it my responsibility to pay for a repair. This would be a slap in the face after going through problems with my first EX1.
Any info is appreciated!
George Kroonder October 14th, 2008 02:50 PM
I'd check out the LCD with a loupe or magnifying glass to check if its a pixel defect or not. It may be that the laminate is seperating like it looked like it was on Steve Cahills' LCD. He replaced the part himself, but you probably already watched that video.
It sounds like a manufacturing defect to me anyways so warranty should cover this. You should take it up with Sony support.
George/
Charles Dasher October 14th, 2008 03:32 PM
SOny service contact info
What is the proper channel to contact Sony service USA? I could go through my dealer but I'd rather go directly. Does any one have contact info for San Jose or Jersey? I believe these are the 2 centers that work on CINEALTA
Greg Laves October 14th, 2008 04:38 PM
Sony Electronics, Inc. Regional Service Center
2706 Media Center Dr Suite 130 Phone: (323) 352-5000
Los Angeles CA 90065 FAX: (323) 352-5039
Steven Thomas October 14th, 2008 04:53 PM
1-800-883-6817 and then press 252
Steve Cahill October 15th, 2008 05:42 AM
I have confirmed that the spots I had were caused by a 8x magnifier that I used outdoors in a hood I constructed to check focus. The sun going into the magnifier "burned" the surface of the LCD it only took a few seconds for this to happen.
See:
http://web.mac.com/stevecahill/Steve..._Go_Wrong.html
for replacement of the LCD.
Alister Chapman October 15th, 2008 06:02 AM
The same thing happens quite a lot to the very expensive LCD based viewfinders that are available for the HDCAM cameras. Leave the eyepiece pointed towards the sun and you are asking for trouble. I expect the LCD in the EX3 could also be damaged in this way.
George Kroonder October 15th, 2008 07:55 AM
Never thought of that... whoh. I'm putting warning labels on pronto.
George/
Serena Steuart October 15th, 2008 08:21 PM
The manual puts it in dramatic terms (camera on fire).
Charles Dasher October 16th, 2008 02:32 PM
I am sending in the camera for warranty service for the battery drain fix, firmware update and hopefully they will replace the lcd. I enjoyed the LCD switch out video. Very informative!
