EX1 with Final Cut Pro 6.0.2
For those who have the XDCAM-EX1, choose the 1080p30HQ for clip format (1920x1080) and use FCP6.0.2 for montage, what is the best setting they found in FCP to preserve the quality of the clip at 1920x1080?
Myself, when importing my clips in FCP, the Sequence settings give me a choice in picture size with the highest being 1440x1080 and does not propose 1920x1080, even if the FCP settings let me to choose the XDCAM-EX environment. Your advice is most welcomed. |
There should be a preset for XDCAM EX 30P 35Mb/s (HQ) which is 1920 x 1080. I use this preset but with the render option in the timeline set to ProRes HQ for most projects.
Well, it is true that when I choose the preset you said, which is 1080p30VBR and I importe a clip, I also make sure that the sequence settings adapt to the clip setting since it is of the highest resolution.
So what I have in the Sequence settings is a image size of 1920x1080 BUT is says that it is HDTC 1080i (16:9), which means that FCP convert this 1080p clip into 1080i. I would herefore conclude that FCP6 does not work with 1080 progressive bu the best it works with is 1080 interlaced. Can you confirm this ? |
The setting is called HDTV 1080i, but if you set the field dominance to none, your sequence will be progressive. That's the setting I've been using for months, and the results are amazing.
Understanding The Terms
If you indeed have a FCP 6.0.2 properly installed then all of the settings are there. When you use "Easy Setup" take a read in the description and you will clearly see the "Sequence settings."
VBR (Variable Bit Rate) = EX1/3 HQ (High Quality rate) = 35MB/s or XDCAM @ 1920x1080 CBR (Constant Bit Rate) = EX1/3 SQ (Standard Quality rate) = 25MB/s or HDV @ 1440x1080 Then as Alister has pointed out set you Sequence to render in ProRes to minimize conforming times and maintain the best possible quality for editing and effects. You also will want to use Software Update because FCP is now at 6.0.4. Sony's XDCAM Transfer utility which also works inside of FCP is now at 2.7.1. |
I am having the same problem as Francois. Can't seem to find the 1920 x 1080 setting in FCP. So all my footage is converted to 1440X1080. It still looks great but I would rather keep it in the original format. [See Diana Scalera on Vimeo for a look]
In addition, over some footage I get a faint green line where render status is indicated. This footage gets fuzzy expect if I put a title or some other effect over it. When I render the footage with effect, the fuzziness clears up. I try selecting the footage and rendering it but the render dialogue box does not come up and there is no change in the fuzziness. What is this green line? How can I correct this? How do I avoid it? I am also using FCP 6.0.2. Thanks Francios for asking this question. Diana Scalera |
Is this the best possible quality you can get out of XDCAM EX from FCP? |
Considering that the XDCAM EX is 8-Bit/MPEG-2, 35MB/s 4:2:0 and ProRes is 10-Bit 4:2:2 I'd say yes and nearly transparent all the way to the Blu-ray discs that I transcode to 35Mb/s in Adobe Encore. If your expecting more than use the SDI port on the EX1/3 and capture at 10-Bit Uncompressed to your heart's desire. Cheers! |
