-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   White Balance Temp. Question (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/134650-white-balance-temp-question.html)
Larry Huntington September 24th, 2008 01:39 PM
On my EX3, I can't seem to manually change the Kelvin Temp of the white balance like I could on my Canon XH-A1- even in the direct menu. For example, I sometimes I like to set a number like 3500k for indoors.
Any EX shooters able to set their own WB numbers?
James Huenergardt September 24th, 2008 01:47 PM
It's in the Picture Profile menu setup.
The White Balance has 3 options. Preset, A, B
A and B are set using the White Balance button.
The Preset is set using the Picture Profile menu. You can set the color temp there.
Larry Huntington September 25th, 2008 03:21 PM
Thanks James, I'll check that out!
Larry Huntington September 25th, 2008 08:44 PM
James, I had no luck finding a temp control under that menu. I even tried the direct menu. It just shows profiles, not white balance settings. I just want to manually dial in a Kelvin number for white balance under "preset". Am I missing something?
Andrew Hollister September 25th, 2008 09:19 PM
Its under White > Preset White in the Picture Profile menus.
Range is from 2100 to 10000 default being 3200
Page 72 of the manual
HTH
andrew
