Clunky Clip Browser
Does anybody else find Clip Browser a bit 'clunky' - eg
I've copied all my clips from 2 EX1s into one folder - each clip is named eg "CAM10001","CAM20045", etc. I'm now working through each clip in Clip Browser marking the sections I want to keep. So to go through them in the right order I click on "Clip Name" column which sorts them into name order. I play the clip, mark IN/OUT points, create a new clip.....and the sort order is lost - so I have to re-sort again. It would help if there was an option to create the new clip with a date stamp of when that new clip was created - rather then the date of the original clip. Also - when marking the IN/OUT points - how about one keypress to create the new clip AND export. If anybody can suggest a better workflow I'm all ears.... Ian |
Ian,
Not completely related to your post, but thought you would quickly know the answer. I am thinking of purchasing the EX1 or EX3 and was curious as to when you import the footage via the clip browser, is there a way to import footage into longer length pieces or does it only import as clips where you hit "record" and then "stop recording" each time? |
Each start/stop recording operating creates one clip. Technically the clip could be made up of many actual files depending on the length of it - but providing you use Clip Browser to copy from the camera to the the PC you don't have to worry about that.
While you can divide clips I don't think you can merge them. Ian |
My Documents not browseable
Another quirky problem I should like to add to this thread is the absence of the "My Documents" folder within the directory explorer. I have tried re-installing and re-downloading but this problem won't go away. Original version worked fine. Although not a biggie (just move the clip folders somewhere outside "My Documents") but is a little unnerving.
I haven't heard anyone else complaining about such a "feature" so maybe this is just an eccentricity of my particular hardware/software (QX6700 quad with XP SP3) causing some denial of access to the user folders under Clipbrowser, anyone else...? |
Dave
Same for me (XP SP2) - no "My Documents" - got to go the long way rounf "Documents and Settings....". Not a major issue for me personally as I copy all clips to a different drive. I gave up with my problem - I exported everything to MXF and will cut it down in Vegas. Ian |
| All times are GMT -6. The time now is 05:38 PM. |
