-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Cannot access Direct menu (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/128227-cannot-access-direct-menu.html)
Petr Bastar August 18th, 2008 03:10 PM
Hello,
I am unable to access the direct menu on the LCD/EVF screen. I managed to do that normaly last week - you only press the joystick or the dial wheel and you are in. I have the CAMERA/DIRECT MENU in PART. I tried ALL and OFF but nothing works. I reseted to factory settings. but still no go in the on-screen menu. Of course no FULL AUTO. I hope I am missing something.... Thanks for help
Petr
George Strother August 19th, 2008 10:42 AM
Originally Posted by Petr Bastar (Post 921722)
Hello,
Petr
Mine does that when the memory card is nearly full. Change cards and menu access comes back.
Petr Bastar August 20th, 2008 06:02 AM
Thank you for the reply. You are correct, I found it myself. I had 0min space on both cards. I deleted them and the direct menu problem was gone. That is strange, isnt it. ??
Thank you again, now I know what caused it.
Piotr Wozniacki August 20th, 2008 06:46 AM
Whenever the camera needs your attention (usually displaying a message, like about low battery or media, or even confirming the change you have just made to some setting), the Direct Menu becomes inaccessible; this is one of the most silly things that crossed the minds of the designers.
