from PMW-EX1 to compuer via HD-SDI?
After recording with the PMW-EX1 onto SxS ExpressCard media cards, is there a way to import the footage into my computer thru an HD-SDI card so I can convert it to an intermediary format via Prospect HD? Or isn't this the way to go?? Would I transfer from the media card to my Hard Drive and then convert?
thanks |
I'de go from the EX1 native to the computer and then convert, only one step. If you go via HD-SDi you must uncompress to send over HD-SDi then re-compress from that to prospect etc, so 2 stages of compression, plus your uncopmressed HD files will be huge and require a very fast raid array.
This thread should really be in the EX forum. |
Hi Robert, I moved your thread to the XDCAM EX forum. Alister has given you some good tips about that workflow.
-gb- |
