Good Chroma-key for EX1 footage
I'm wondering if any of you have tried keying the EX1 footage?
I've used the DV Matte Pro 1.5 before on DVCPRO50 4:2:2 footage with good results, but since the EX1 has 4 times the resolution it will outweigh the 4:2:2 advantage? If any of you have some great key settings that work good, i'd appreciate a look :) |
Sure it's solid- as with any camera good lighting is critical.
Noah |
Keys great - much easier than with DV 411. In fact, I've used the in-camera color correction function to goose the chroma and shift the hue on the CK background during the shoot to get a better key. I use spectramatte in Avid Media Composer.
Other hint here is to shoot progressive rather than interlaced. I am amazed at the ease of pulling a clean key from EX footage considering 4:2:0 footage
Chroma keying and EX1
Hello Øyvind,
Check this link, if you like. My friend Pål has been using the EX1 on quite a few of his chroma key projects: http://www.vimeo.com/1054795?pg=embed&sec=1054795 I just received my EX3, but haven´t tested it´s chroma key abilities yet. I´ve used DVCPro HD so far for all my chroma key projects, but I don´t expect XDCAM to be a problem at all. I use a portable Reflectmedia rig for my projects. Best of luck to you and your projects. Best, Terje Rian |
2 Attachment(s)
PS: tip for future: if presenter is wearing watch, at least pull the winder knob out so the dial doesn't jump around when you're editing. |
here's a quickey I did just the other day.... I'm sure it can be done better though....
http://exposureroom.com/members/witz...b88bcbfa373db/ used the basic keyer in FCP it keys much better and easier than the z1 ever did for me. |
I have DV matte pro 1.5, but I cannot see that v2.0 exists..
Not sure what happened to the naming conventions... |
I posted this elsewhere before but our host is always shot against green screen:
http://www.hawaiigoesfishing.com/vid...een_sample.mov Using a green screen from EEFX.com, lit with two Tota Lights. The keying is with After Effects using a Primatte plug-in from Red Giant Software. Primatte has tremendously flexible controls, essential for getting fine details such as hair. Everything is shot 1080p30. |
| All times are GMT -6. The time now is 10:31 PM. |
