-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   How do you check the firmware on the EX1? (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/126934-how-do-you-check-firmware-ex1.html)
James Huenergardt July 29th, 2008 02:58 PM
Hi,
I just purchased a second EX1 and wanted to see what firmware version it was running.
I looked all through the menus and couldn't find anything on it.
How do you view what firmware version the camera is running?
Jim
George Kroonder July 29th, 2008 03:13 PM
It's in the maintenance menu. Press and hold MENU and CANCEL on the rear of the camera, then press SEL/SET to access.
George/
Jurgen Taghon July 29th, 2008 04:08 PM
firmware update
When will it be possible to update to a newer version of the firmware for the ex1 by the yourself?
And what makes the difference with newer firmware.
thanks jurgen
Ronn Kilby July 29th, 2008 05:00 PM
Strange. Since I got my EX-1 back from Sony Repair, the "Menu/Cancel/Sel-Set" does not display the Maintenance Menu. I'm sure they updated the firmware but I can't check it.
Brent Ethington August 23rd, 2008 12:32 PM
I just found that the procedure is: Press and hold the "CANCEL" "SEL/SET" and "MENU" buttons simultaneously.
Juan Solorzano December 6th, 2008 10:57 AM
How to hide the maintenance menu?
I recently sent my EX1 to the local Sony service center for the firmware upgrade. When I got it back I wanted to be sure they installed the latest one (1.11) so I pressed Menu_Sel/Set_cancel. Everything fine..
Now is there a way to hide the maintenance menu again.. since I donīt want one of the videographers I worke with messing with it?
Erik Phairas December 6th, 2008 11:08 AM
on my ex3 I had to do this. All three. Removed by shutting the camera off.
V1.02_0078
