Is 35Mbs the Long GOP limit?
Does anyone know why Sony settled for 35Mbs as the data rate and whether if we buy into the EX series whether we could expect increased data rates (and therefore quality) in the future (eg by dialling it in)?
And why did they choose 4:2:0 - to protect more costly models? But I think the Panasonic HVX200 has 4:2:2 and its a budget HD model? Is this why Scarlet will be revolutionary because it breaks the way Sony differentiates between quality and cost? I just find all this quite baffling. Thanks |
First let me say I am no expert here, but I think you are really missing a lot of the point of the camera.
No, 35Mb is not the limit for long GOP. But it is "good enough" for what this camera is supposed to do. In the same vein as saying that 120 mph is not the upper limit of speed for an SUV, but for it's intended purpose, that's more than enough. The HVX200 does offer 4:2:2 color sampling, but it's doing that sampling on a much smaller picture. It does not read 1920x1080 like the EX1. It is reading 960x540. In terms of why 4:2:0, that's what the Mpeg2 profile the camera records in, dictates. In order to be compatible, they had to work inside the standard. Scarlet will be revolutionary for a number of reasons. It will overscan the 1080 image we are used to. It will record with more color space. It will do a lot. And it will do it at an amazing price point. What Scarlet will not have is a native recording scheme that is compatible with what we all shoot now. It's like us all having CD players, and a new unit comes along that has DVDs. We can all make the jump, but it's not compatible with what we're doing now. Honestly, I think that's ok, but it's going to be a big change for some folks. Very few people will be able to edit 3k video on their current DV/HDV editing computers. But you do realize that the EX1 has SDI output, right? Something very few other cameras in our price range can claim. This bypasses the 35Mbps 4:2:0 long GOP sampling and offers 1.5Gbps 4:2:2 "uncompressed" sampling just like the $150k cameras. Yes, the lens is nowhere near as good, and there are other differences as well, but the EX1 is fully capable of offering video quality other cameras in this price range couldn't dream of. Quote:
I think (although I don't know for sure) that 35Mb was chosen initially because it was a data rate that could easily be written to the discs used in the F350/F355 camera line.
I suspect it is 4:2:0 as that's how MPEG2 is normally encoded. While 4:2:2 MPEG2 is now possible it is not "normal". Sure the HVX200 is 4:2:2 but the whole image is sub-sampled first. The numbers do not tell the full story. Perhaps it is 4:2:0 to protect high end products, but then HDCAM is 4:1:1 which has no more colour information than 4:2:0. In progressive 4:2:0 tends to look better than 4:1:1. While Reds products are capable of producing stunning pictures and may well be cheaper per pixel than mainstream manufacturers there is more to it than that. For example where do you go to get a Red One repaired if it breaks and your not in the US? I have always found Sony's products to be well made, even at the cheaper end of their ranges. The best bit is that we now have so much choice. |
35Mbps certainly isnt any kind of limit on long GOP in general, if thats what you were asking. Look at convergent's XDR, they are encoding 100Mbps long GOP 4:2:2 video using sony's codec. Quote:
wow two people responded while i was writing my response, sorry if my post was redundant at all.
I dont understand the "good enough" - after all, they would simply have an even more incredible camera if the data rate was 70Mbs (and associated increase in pic quality) wouldnt they? I understand Alistairs point on the limitation of SxS cards - that implies that unless you get faster cards you cant increase the data rate I think. Quote:
If we ignore for a moment camera handling, support, familarity, accessories and whatever else people use to make decisions to buy a camera and focus on just 1 thing - picture quality - if I want to output to (a) DVD (b) Blue-ray outputs - why on earth would one purchase a HVX200 or 201? Are there situations where the 4:2:2 colr space gives me some sort of advantage, eg, an indie movie as opposed to ENG? Quote:
sxs cards can certainly handle more than 35Mbps. Slow motion footage is written to the card at quite a bit more than 35Mbps. 35Mbps sounds like it might be a limitation of the original optical media used for XDCAM. that number is pretty close to the higher end of the specs for blu-ray delivery in mpeg2 i believe, so that might be an indication that the discs or encoding/decoding equipment may have been limited to about 35Mbps at the time... just a guess
Let's take these one at a time...
Reference here: http://www.mediacollege.com/video/fo.../dvcprohd.html Quote:
HD-SDI video is no joke to fool with in post. That's for sure. But neither is RED's 4k. There are ways around this. Like working with proxy files. When films are cut on computer, generally they are edited with proxy files that are much smaller. Cutting on 720p proxies is MUCH easier. So you do that, then apply all changes to the original media, and let it render. That's actually how I've been dealing with 1080p files on my older workstation. At least until I started using Cineform. |
http://www.dvinfo.net/conf/forumdisplay.php?f=166 The devices use the same codec chips as in the Sony cameras, only pushing the chips to their full potential, and give a glimpse into the possible recording option of future Sony cameras in the Prosumer line... but allowing you to access that potential today. Regards, Jim Arthurs |
I think Sony did this EXACTLY right.
Give you HDV off the Firewire port, give you XDCam to onboard recording, and give you HD-SDI out for high end off-board recording. Something for every market. Very flexible. If Sony had gone to the 100mbps or 160mpbs for their onboard codec, the recording times would have been horrifically short and VERY expensive. Like the original 2GB P2 cards, or the original Compact Flash cards in the RED. Very few people are going to be happy spending $800 to get 4 minutes! Quote:
Just a note that the second paragraph in my quote in the above reply are your thoughts, not mine. No problem, I think you just didn't seperate my statements into two parts when you quoted me...
Sorry Jim, I missed it.
-gb- |
| All times are GMT -6. The time now is 09:38 AM. |
