How does EX-1 compare with digibeta
Can anyone tell me how footage compares between a digibeta (sony DVW970P / Sony DVW-709WSP etc) and a EX1?
I like the 2/3 chip of the digibeta , combined with their low compression, but they don't have under/overcranking abilities for fast/slow motion Anyone? |
Btw, downconverted to SD the ex1 gives 4:4:4.
thanks |
The ex1 records 960x540 chroma-pixels at 1080p, which is more than 720x480 luma-pixels of NTSC-SD. So after resampling to 720x480 you have unique chroma-information for each luma-pixel. And this is what 4:4:4 means.
The only HD format that turns into 4:4:4 SD is 4:4:4 HD. You do not benefit from the larger pixel count when you scale your footage.
Here's an example of scaling ex1-footage down to sd: http://www.dominik.ws/ex1tosd.png The first row is dv25, the second dv50 and the third no further compression. The first column is rgb, the second is the a-chroma-channel and the third the b-chroma-channel (I used Photoshops Lab-Color-Mode and increased the contrast for better visibility). |
It's a nice example. But it doesn't match what I see in my scopes, so I will stick to my statement for a while.
If I export a 4:2:0 HD (XDCAM HD) source to a 4:4:4 SD (AJA RGB) source I don't gain any chroma information when I review the footage in color's scopes. So either I am missing a step here or... We are talking about two different issues. Please enlighten me. |
My point exactly.
But if there was an easy way to keep the extra information in the chroma channel, I would love to hear about it. And to get back on topic. Down converting or up converting are in their very nature destructive and will have a negative impact on image quality. So no, the EX1 does not produce better SD images, than for instance a sony DVW970P. It is widely accepted that if your final master is SD and the footage will never be used in HD, then shoot in SD. But if you are caught in the middle, like the rest of us, then HD is the only way and there the EX1 really shines as a price performer. As long as you are aware of its shortcomings. I have tested all of the scalers/format converters on the market and none of them really delivers. The best hybrid is to master to HDCAM SR or D5 and use their internal scaler boards to create a digibeta dub. It is the most consistent result with very few nasty surprises. |
The example I posted shows pin-sharp chroma-channels. What do want more (ok, the mpeg2-compression has some impact, but that's a different story)?! |
Dominik's sample answers this question very clearly and is probably the best demonstration of it that I've seen. To test it with the scopes in color as you're doing Nils what you need to do is export an XDCAM source to both uncompressed 4:4:4 SD and an uncompressed 4:2:2 SD to represent what you get from digibeta (or try shooting the same subject on digibeta for the most accurate comparison). Compare those and see if you don't see an improvement in chroma information in the 4:4:4 SD export vs. the 4:2:2 SD digibeta source. |
So don't came and tell me that downconverting is not good, because that's just what the best SD cameras available at the moment are doing to perform the best quality. The choice of doing it before or after recording is more depending of personal preferences than of technical evidence. |
