-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Would upgrading to FCP eliminate need for XDCAM Transfer software? (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/123171-would-upgrading-fcp-eliminate-need-xdcam-transfer-software.html)
Akira Hakuta June 6th, 2008 09:37 AM
I'm currently running FCP 5 and am wondering if upgrading to 6 would eliminate the need to use XDCAM Transfer as a middleman software? If so, would that save more time in the importing process?
David Chia June 6th, 2008 10:56 AM
No you still need the sony software. It just that with FCP 6 you can edit the HQ clips instead of just the SQ clips from the EX1. When you import from FCP 6 it opens up the Sony software
Doug Park June 7th, 2008 11:35 AM
Akira,
Right now there is no difference with the workflow, you would still need to use XDCAM Transfer with FCP6. This will change though...and hopefully soon. Apple is showcasing a new Log and Transfer plugin from Sony on the Final Cut World Tour. Here is a thread on it:
http://www.dvinfo.net/conf/showthrea...t=log+transfer
