-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   No iLink in menu (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/119475-no-ilink-menu.html)
Phil Hanna April 15th, 2008 11:40 AM
No iLink in menu
I am trying to connect iLink to my computer and do a test with iMovie. I have the proper firewire cable, but when I go to the EX-1 menu to enable iLink, it is grayed out and I can't access it. Has anyone else had this issue and if so, how do you correct it?
Phil Hanna
Craig Seeman April 15th, 2008 11:52 AM
I'm not in front of the camera at the moment but you might have to disable HD-SDI out. I think iLink is one of those either/or choices which involve disabling or changing some other nearby output setting.
You're not really mentioning what exactly your setting up which might give us more clues. Did you already record in 25mbps or are you trying to record live to iMovie?
Zenes Petrusin April 15th, 2008 11:53 AM
You must set SP1080/50i first
Dave Morrison May 5th, 2008 04:42 PM
I'm running into this same problem. I could NOT access the greyed out iLink menu item. I also checked the manual and verified that I did NOT have the SDI output turned on as this would disable iLink. Has anybody figured out why this doesn't work?
Charles Young May 5th, 2008 09:12 PM
You must choose the SP 1080 modes from the "Others" menu. the ILink will then not be grayed. The camera must output 1440X1080 25Mb to be ILink compatible.
Dave Morrison May 5th, 2008 09:24 PM
Ahhh, okay. I was hoping that I could use the iLink/Firewire connection to tranfer files from the camera but it looks like they only intended it for outputting video in the lower res formats. NOW it makes sense. Thanks.
Bruno Demeocq May 5th, 2008 09:40 PM
Usb
In HQ, U can use the USB.
