Thread Tools
Search this Thread
#46 |
The cine gammas are downright strange and they are different from one another. All seem to have an extreme amount of knee compression that sets in very early, so if you were just looking at 100% zebras ( at least with some of them they might not show you much until a good part of your image was in the compressed knee.
Be careful with them. BTW it seems if you decide to alter the gammas even a little bit the curves start altering radically in the knee area. They are particularly dangerous around flesh tones ( esp cine 3 ) and can easily give you compressed areas in faces. |
#47 | |
Standard gamma curves do not controle that and rely on the knee function to handle high IRE, leading to color aberation around highlights. Cine curves are spreading the sensibility of the CMOS where it is needed, sometines more in the blacks, the middle or the brights. I don't understand what you mean when talking of "usual bright picture" opposed to film look. Use STD gamma for a video look (high saturated color, crushed blacks and burnt hightlight). Use the CINE gamma to get the whole sensibility, without blowing out the hightlights and beeing able to edit in post. I haven't seen the curve of the EX1 STD gamma, but I bet it is like the one on the XDCAM-HD, which is almost the same as other Cine-alta from sony (like F900). |
#48 | |
#49 |
Michael...
I'm not gonna retract what I'm suggesting, however, I will add the same thing that Leonard Levy said. The knee function is strange. It's understandable that you're dubious. I'm basing my opinion on the waveform displays in HDRack, which kinda knocked me out of my chair when I saw them. In shooting tests, I'm finding that CINE gamma is a lot more forgiving than the STD curves, Mike. There are situations where that isn't true, tho'. The STD curve images are real "punchy", not terribly pleasant without some CCing...;o) |
#50 |
Ultimately I wish someone would shoot some test charts and scopes and post the video or shots online because I think the terminology and explanations are confusing some.
#51 |
Yep ! .....
Round 2 GH5,FZ2000 |
#52 |
Here's some outdoor shots with my TC2 at 4 gamma preset settings, for comparison. I'll try to get some screenshots of the wfm for a DSC testchart, later, when I have some time.
TC2S1=STD1, TC2C1=Cine1, TC2C3=Cine3, TC2C4=C4 |
#53 | |
You know way more about this than I, so I hesitate to comment, but this seems counter indicated by your examples above. You are very close to blowing both blacks and whites on your STD example, but have a bunch of headroom on your Cine examples. Did you reverse your initial comment? If not, I am lost, so set me straight. Also, it seems like in your Cine Examples, a little push to the right might nail the whites and set the darks in great position for a little level/curves tweak in post without introducing a lick of noise. |
#54 |
Randy..
Can't argue with you. And...not so sure I know more than you. You're quite right. You say I'm very close to blowing whites on STD...yes, but they're not, are they? I expose so 100% zebra is just beginning to show...as you just confirmed.And it recovers quite nicely with a little levels adjust with the Color Curves FX. The cine curves need that push to the right, indeed! The histogram showed that STD1 fills the scale, while the CINE presets pushed the histogram to the left. In my mind, that's wasted bandwidth. Playing with color grading in post reveals that STD1 can be tweaked with more detail than the CINE curves. And that "punchy" look in STD can be moderated, again, with a little reverse-"s" curve adjustment.Try it. By the way....the auto expose selected by the EX1 was really effected by where I took the exposure...sky or foreground. It seems to work just like a spot meter rather than an averaging meter. Either way, I didn't like the camera selected autoexposure. I used zebra, as I explained. |
#55 |
Bill, when I come to your lovely home town of Santa Fe on Saturday I would love you to give me some complete PP settings for shooting outside.
Cheers! Phil |
#56 |
Seems like a consensus is being reached on this between you and me, Bill :)
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
#58 |
I agree with Randy that maybe the CINEs could be pushed more, but to my eye I see more highlight detail to work with in the STD. Of course, there may be detail in the CINEs that might come out in post not obvious here. Would be interesting Bill if you took those four shots and gave them some post to get each one the best you could and then post those four.
Typical New Mexico that. I lived in Taos once. Mike |
#59 | |
What had me confused was the part about being more likey to blow something with Cine than STD. I have been considering Cine as "safety settings" for high contrast or variable contrast scenes. In surf shots, I am dealing with random occasional whitewater exposions on relatively dark water. I am just not ggod enough to be that accurate in selecting the perfect setting and need to "compress the histogram" (whites in particular) a bit. I have been using your PP's (dig them) with Cine's pushed to the 100 zebra setting (waiting to judge based on the worst whitewater explosion) and then backed off a bit. Leaves a bit of room under the darks, but a curves/levels adjust fills the histogram back out. Definitely some waste as you stated, but less missed shots due to blocked up whites as well. Learning...learning |
#60 | |
