-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   No MetaData in Clips? (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/113856-no-metadata-clips.html)
Michael H. Stevens February 3rd, 2008 01:53 PM
When reviewing clips to compare profiles I was surprised to see there is no meta data with the clips to identify the camera settings used. Is this not expected, or is it there buried deep?
Andreas Johansson February 3rd, 2008 05:11 PM
Doesn't the meta data get written in the xml files besides the mp4 clips?
Ian Smith February 3rd, 2008 05:24 PM
I seem to remember from the "Mastering the Sony PMW-EX1" DVD that they mentioned how little metadata was captured in the EX1, to the extent that the Clip Browser was pretty much described as a program for manually entering metadata before the file was exported in a format the your NLE would understand.
Andreas Johansson February 3rd, 2008 05:34 PM
There is meta data of fps, rec format, duration and such in the xml files.
Michael H. Stevens February 3rd, 2008 05:49 PM
True, but this is of little use if you want to know how a look was created. I'm talking about the PP settings not basic stuff like frame rate.
Steve Mullen February 3rd, 2008 10:09 PM
The EX1 is a curious device. It lacks some of common features--such as very fast, very accurate AF and Data Recording--that are present with Sony DV/HDV camcorders. And, it appears the meta-data of the XDCAM HD units are not available.
Note that PP data is not recorded by HDV camcorders. When testing I usually verbally record setting data.
