-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Slow Motion (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/113464-slow-motion.html)
Michael Stewart January 28th, 2008 11:44 PM
Slow Motion
I'm shooting 24p and want to slow the footage down to 50 percent not 40, so I set shutter at 48, but it seems strobe like anyone have a clue why?
Mike
Eric Pascarelli January 28th, 2008 11:47 PM
Did you set it to 48 on the S&Q menu?
How's your shutter set? Try setting it to angle mode at 180°
Describe the strobing, or post a small quicktime, if you can.
Sami Sanpakkila January 29th, 2008 06:04 AM
Are you shooting indoors or outdoors? Fluorescent lights could cause that as well. It happens to me indoors if I shoot at 60fps. 50fps has no strobing.
Evan Donn January 29th, 2008 01:15 PM
shutter speed or frame rate? If you want to shoot 50% slow motion you need to shoot at 48 frames per second, not a 1/48 shutter speed. I'm not sure if 48 fps is an option on the EX.
Eric Pascarelli January 29th, 2008 01:21 PM
48fps is an option on the EX1, but only at 720p. It's selected on the S&Q menu.
Michael Stewart January 29th, 2008 05:47 PM
Sorry, just got home. I am shooting 48fps SQ mode, 720 24p, indoors. There were flourescent lights.
Mike
Eric Pascarelli January 29th, 2008 05:53 PM
Fluorescents will flicker at 48 fps. at 180° (1/96 sec) shutter or no shutter (1/48 sec). Try 1/60 shutter.
Michael Stewart January 29th, 2008 09:09 PM
Thanks Eric, I'll try it.
Mike
Craig Seeman January 30th, 2008 07:34 AM
I wonder if Flicker Reduce menu setting would have impact. One might think that it's function is to reduce flicker when shooting at NTSC frame rates in PAL regions (50Hz electrical actually) and vice versa. What it's actually doing (since it's not changing the shutter speed) is a minor mystery to me. One might think it can help fluorescent light flicker.
