-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   "Cannot Proceed" - Solved (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/109148-cannot-proceed-solved.html)
Phil Bloom November 27th, 2007 05:07 PM
manual gain...cannot proceed
Not sure what I have done, but have done it twice now. I cannot change gain when in manual mode. I keep getting the message "cannot proceed". Last time I reset all settings and it was fine, but I don't want to do this again.
Any ideas?
Chris Forbes November 27th, 2007 05:11 PM
Ditto for me I was messing with the settings and got the do not proceed error. I had to reset the settings.
Phil Bloom November 28th, 2007 01:28 AM
Am wondering if there is a bug in the firmware here that needs fixing
Eric Pascarelli November 28th, 2007 07:22 AM
Same here - for both the Gain and the White Balance switches.
Phil Bloom November 28th, 2007 07:48 AM
Definite fault. Am sure it will be fixed soon.
Chris Forbes November 28th, 2007 12:54 PM
try to adjust the on-screen options with a tape or battery warning up. It doesn't work.
Phil Bloom November 28th, 2007 01:04 PM
Hey...we are the beta testers after all in a way! Do Sony read these forums at all?
Carroll Lam November 29th, 2007 04:04 PM
How are you trying to change gain, Phil - by using the PRST-A-B switch or do you mean you can use the menus to set the values for the switch settings?
Carroll Lam
Phil Bloom November 29th, 2007 04:09 PM
its using the hard switches. When it happens it affects the white balance switch too
Carroll Lam November 29th, 2007 04:32 PM
Thanks, Phil. I just wanted to be on the watch for the same problem.
Carroll Lam
Carroll Lam November 29th, 2007 05:41 PM
Others have posted about the manual gain setting switch and I have about the manual shutter switch sometimes leading to a "cannot proceed" message, requiring an "all reset" to restore normal operations.
Well, I just finished an experiment where I painstakingly changed one menu setting at a time away from the factory default settings. I didn't change every parameter, just the ones I had been changing to my preferences.
When I finally got down to "Direct Menu" and changed it from "Part" to "All" I started getting the "cannot proceed" warning when I operated either the shutter or gain switches. So, out came the manual and sure 'nuff there at the upper right of page 19 were the words "When the Direct mode is set to "All," tje GAIN, SHUTTER, and WHITE BAL switches are disabled."
Now, I'm a great believer in RTFM and I had studied the manual quite closely and I'd studied the manual for days before receiving my EX1 and I missed that statement completely.
Now that I understand what Direct Menu is and how it works since having the actual camera I can see the logic of this method of operation but I wish the preceding statement had been highlighted a little better.
"All is forgiven."
Carroll Lam
Chris Barcellos November 29th, 2007 05:54 PM
Thought it would be something like that....
Zachary Fink February 3rd, 2008 10:11 AM
thanks
Thanks - That stumped me as well
Andreas Johansson February 3rd, 2008 05:39 PM
If I was a Sony rep and did read this I would reply with a classic RTFM!
Maybe we don't want Sony to read all our post :)
Billy Mead February 3rd, 2008 07:09 PM
Yeah.. had me for about 20 minutes tonight. Thanks GOD for the search function here!
But the error message itself is kind of creepy. 'Cannot Proceed' just plain sounds bad...
