If in your example the Z1 had a S/N of (say) 56dB at -0dB, and the EX had 50dB at -3, you'd have to set the Z1 to +6dB to make relevant comparisons. |
If in your example the Z1 had a S/N of (say) 56dB at -0dB, and the EX had 50dB at -3, you'd have to set the Z1 to +6dB to make relevant comparisons.[/QUOTE]
Interesting comment. Though I really would like to know how you have worked this out. So how can I compare my existing Sony camera (DSR 300) rated at sensitivity of f11 @ 2000lux with a S/N of 62dB with the EX1 rating of f10 @ 2000lux with a S/N of 52dB? Until I've read your comment above I thought that I will have a third of a stop less - but I'm not so sure now. Any feedback would be most welcomed. |
from the horse's mouth...
An ASA rating only fixes the first two, so a statement such as "this camera is rated at 800ASA" is, by itself, meaningless.
It's not meaningless at all. If you shoot 35mm film, the ASA rating tells you how fast the film is, and therefore what light levels are required for the exposure you desire. Jeff Cree and I lit a chip chart with a specific, measurable volume of light, adjusted the iris on the XDCAM EX for correct exposure utilizing a waveform monitor, used no gain, no N.D., frame rate was 23.98P, then measured the light with a Spectra light meter and determined the camera was rated at about 800 ASA. So for me as a D.P., I can light for the XDCAM EX the same as I would 35mm film rated at 800 ASA. If I want to use my light meter for lighting with the XDCAM EX, I can set it for ASA 800 and I'm good to go. For those of use who rarely if ever use a light meter, the value of knowing it's rated at 800 is at the least a guide that tells us, "This camera does not need much light to make properly exposed images." 800 is darn fast, particularly when you know the F900 is below 400 (closer to 320). Shooting at 24P or 60i changes things, but the baseline is indeed useful and meaningful. If I can find my notes and comparisons with the F900R and XDCAM HD F350, I'll share them. |
But are you sure about the 62dB figure? It sounds somewhat high. In practice, things get much more complicated, since prosumer cameras like the PD150 add processing as the gain is increased to reduce the noise - but at the expense of degrading the picture in other ways. My "quick and dirty" test (in the absence of S/N meters etc) is to take both cameras somewhere pretty dark, open up the irises, and add gain to get correct exposure. Then compare pictures. |
*IF* the 900 had an inherently much less noisy picture at 0dB setting, such that 9dB (say) could be put in without it being any noisier than the EX at 0dB, that would make it inherently MORE sensitive than the EX, even though it has a lower ASA figure at 0dB. Exactly as with a DSLR, which can have any value from 100-3200 dialled in. How do you define it's sensitivity then? You have to specify the third parameter with electronic cameras to get like for like comparisons. |
True, though if the EX1 is squeezing off 800 ASA at -3dB, I'd bet that it is fairly clean too.
David you are correct for wanting exact signal to noise reference to compare cameras. I'm willing to believe Jody regarding the EX1 sensitivity. By the way, welcome to the board Jody. You're well respected in my book. |
There's not much point in debating in theory how one camera might perform relative to another, we just have to set them up and test. However the 800 rating has been obtained by various DPs whom I believe to be critical reviewers, so until I get hold of one and prove them wrong I don't see much to argue about. Anyone wanting really great low light capabilities will test before buying. Also there is a lot more to a good image than low noise (speaking as someone who remembers Tri-X).
Thing is though if the camera is at -3dB what the S/N ratio is, is kind of irrelevant in terms of the ASA rating, the same as it is with film. There's nothing you can do about it. Increasing the amount of light means you've either go to iris down or up the shutter speed otherwise you're over exposing.
Now hopefully Sony haven't sacrificed S/N to get a higher sensitivity, that'd really bug me as there's nothing you can do about it. Noisy images in low light from upping the gain are one thing, noisy images in daylight are another matter. |
Yes David - actually I've checked again and my model is the DSR-300P and it is rated as 60db, The DSR300 is rated as 62db (which I believe is the NTSC version of this camera). It is one hell of a beast when it comes to film in low light and in the past 9 years I very rarely used any lights at all - and when I did, I only used a 20 watt lamp on board powered by the camera itself (for event/wedding filming). Obviously I use gain between +6 and +9 (never more) and one can detect some grain - however the ability to film quickly and unobtrusively without lights and producing a good picture far outweighs the fact that some grain can be detected. Having said that recently I viewed some of my work (SD) on a 40' Panasonic plasma (full HD) via a PS3. The picture was awesome and the upscaling managed to hide most of the grain! |
Will leave the real techie stuff to you guys but with a new camera, much like a new film......theres not a lot of actual test footage floating around the net.
Thinking of the movies that don't get coverage before they are out. Anyone who has seen test footage actually disapointed with the EX1? |
Not giving S/N figures is analogous to giving someone two different maps without scales. Each is accurate and useful within itself, but useless for comparing RELATIVE distances from one map to the other. Quote:
All this said, my own quick looks at the EX make me feel that it's sensitivity performance is very good indeed, and it substantially outperforms other cameras in this price range. |
David, agree with your technical argument and just suggesting that until we get the camera it's all a bit academic. The 800 figure predicts that we'll find it much better in low light than available HDV cameras, but until we see what Sony has built in for noise suppression and what effects that has on image quality we really are in the dark.
Well, in a couple weeks there will be a lot more info.
My camera should be in my hands the week of Thanksgiving. At worse, the week after. |
| All times are GMT -6. The time now is 11:00 AM. |
