-   Sony VX2100 / PD170 / PDX10 Companion (https://www.dvinfo.net/forum/sony-vx2100-pd170-pdx10-companion/)
-   -   PD170 'red flaring' problem.. (https://www.dvinfo.net/forum/sony-vx2100-pd170-pdx10-companion/86863-pd170-red-flaring-problem.html)
Anthony Milic February 19th, 2007 12:55 AM
Hi Folks.
I was inside filming yesterday and suddenly found some pretty serious red flaring occurring on screen. Mostly things like lights and highly reflective objects were flaring right up. It looked very wrong. It was not a 'standard flare' you might see in filming intense lights or similar.. it was more of a flat 'unnatural' bright red. (if that makes sense).. It was very 'alien'. The type of thing that makes your stomach clench and that little voice tells you.. "..that is not good..."..
Edges of clothing, face edges also flaring.
In some ways similar to maxing the colour setting right up on a tv.
Flaring was visible on eye-viewfinder and view screen. Yet unknown if flaring was visible on recording or on monitors.
I film in this controlled area regularly. Same lighting same setup. The only difference today was that I was splitting the video output to two monitors through a simple Y splitter.. though I can't see how this would be related.
What seemed to cause it was this: As I was looking through the viewfinder, I was ever so gently feeling my way to the red record button (incorporated into the power switch) and accidentally tapped the little power switch tab. At that moment, the red flaring appeared, seemingly as direct consequence of this gentle little tap!! Weird.
Have tried altering all manual settings.
Have switched on off. no change.
Any ideas?
Craig Seeman February 19th, 2007 09:09 AM
Try the reset button and hope it's just a software issue.
Anthony Milic February 22nd, 2007 04:38 PM
Thanks Craig!
I've tried (reset), and I've hoped. But no result.
Still getting this red distortion on screen.
Lot's of red vertical striping.
Has anyone out there seen or heard of this before?!
Anthony
ps. (comes up on playback)
Don Bloom February 22nd, 2007 06:05 PM
There was a recall on PD170s that fell into certain serial number sequences for bad CCDs which were replaced at no charge by Sony. I THINK somewhere in the Sony forum here there was a notice posted about this and had the contact information. You might look thru or search this part of the forum for that info.
Here's some info regarding this problem.
HTHs
http://www.dvinfo.net/conf/showthread.php?t=53549
http://www.dvinfo.net/conf/showthread.php?t=73461
Don
Anthony Milic February 23rd, 2007 05:53 PM
A place to start.
Thankyou!..
Graham Risdon February 24th, 2007 03:06 AM
1 Attachment(s)
I had the same problem with a DSR-250. My service guy rang Sony and they sent a courier with a special packing case, shipped the whole lot to Belgium, replaced the CCD block and I had the camera back within 10 days. I've posted a grab of the fault. The camera was about 3 years old, I had no extended warranty and paid nothing.
Hope this helps
Anthony Milic February 26th, 2007 12:02 AM
That's it Graham!.. but in red.
Sony have referred me one to their service centres..
I've spoken with two of them.
Unfortunately both indicate that I'll be up for cost of delivering the unit, quotes, parts, labor and return of camera.
Doesn't sound as good a deal does it..
Any suggestions?
(Camera is 4 years old, I suspect the extended warranty has expired.)
