vx2000 exposure problem
I've had 2 vx2000 cams for two years. I can have both of them pointing at the same thing, same iris settings, same light, same everything. One of them, however, is a little darkish. Not real dark like the ND filter has been left on, but just darker than the other. I can brighten it up in post, but it's a real pain to always have to match the two.
The exposure has always matched perfectly until about a month ago. Now that one is just darkish. Does anyone have any idea what happened, or what I need to do to fix it? Thanks... Nancy |
Hi Nancy, and welcome to DVinfo!
One other thing to double check: is the zoom setting the same on both cameras? This could be a factor if you're shooting with the iris wide open in manual mode (displaying OPEN in the viewfinder). At full wide zoom "OPEN" means f1.6 but at full telephoto it means f2.8; everything else is somewhere in between. So even though both cameras say OPEN they might have different f-stops. Probably not what's going on, since you say it just happened recently, but thought I'd toss it out just in case... If you can't figure out the problem then one thing which might help would be to turn on the zebra patterns on both cameras and adjust one camera until it matches the other one. |
You might also want to look into the Custom Presets menu and adjust slightly to better match the 2. My 2 150 had a similar difference and the 250 also has a bit of a difference-just enough to make it a PITA in post but with a little play it can be made to a perfect match.
Don |
Nancy |
Of course, a work-around might be just fine, as I'm probably going to go with HD next year anyway! thanks... Nancy |
Another work-around might be getting a screw-in ND filter of the correct variety and leaving it on whichever camera is consistently brighter.
Oh-oh Boyd. I'd not recomment the extra ND route, not with the custom preset menu so easily able to match the two cameras.
| All times are GMT -6. The time now is 05:39 PM. |
