Pd 150 Help...
Hi I have a pd 150 and I cant figure out how to turn on the rec clock. I hit record and I have no idea how much tape am using. I went through the menu and cant find anything to turn it on. It just reads 00000s. Please help...
Thanks lou |
If you mean the timecode display, then I firstly ask if you have tried with another tape? I'm not so sure if it's dependant on the tape though.
I don't know if you have a manual, but to display timecode, you open the lcd screen, and select display button in the left hand upper corner. Here is link to manual, if you don't have it.
http://beallcenter.uci.edu/facility/...ini_DV-Cam.pdf |
Open the LCD push MENU button-use SCroll wheel and scroll down to the little icon that looks like a tape(6th one down) push scroll wheel in to lock it to that icon The menu will read: REC MODE, AUDIO MODE,Tape REMAIN-it sounds like thats the one you want -push the scroll wheel in to lock it to the icon and it will read AUTO-push wheel in to get it to read ON - push wheel in again and it is locked to ON push MENU button again to exit menu.
Now you'll know how much tape is recorded AND how much is left. Don |
| All times are GMT -6. The time now is 01:12 AM. |
