-   Sony VX2100 / PD170 / PDX10 Companion (https://www.dvinfo.net/forum/sony-vx2100-pd170-pdx10-companion/)
-   -   On PD170, DVCAM & DV SP Question (https://www.dvinfo.net/forum/sony-vx2100-pd170-pdx10-companion/27892-pd170-dvcam-dv-sp-question.html)
John Carey June 21st, 2004 11:27 PM
In the menu on the PD170, you can choose your format, DV SP and DVCAM. What would happen if you put a regular DV tape in and kept the format to DVcam?
John
Tom Hardwick June 22nd, 2004 10:32 AM
What would happen? You'd record 40 minutes of DVCAM footage.
Boyd Ostroff June 22nd, 2004 04:29 PM
...and save a lot of money, as compared to those expensive DVCAM tapes. From what I've read this is what most people do when shooting in DVCAM mode. Works fine for me personally...
John Carey June 22nd, 2004 06:17 PM
what differences are there
what differences are there when recording dvcam or dv sp on a regular DV tape besides the 60 vs 40 minutes?
Boyd Ostroff June 22nd, 2004 06:30 PM
As I understand it, none. But the DVCAM tapes are manufactured to a higher standard. There's nothing specific that makes them suited to DVCAM. Do a search on this topic, it comes up frequently and you'll find lots of comments.
Tom Hardwick June 23rd, 2004 12:14 AM
What differences are there John? For all practical purposes, none whatsoever. There are however some pros and cons. The first pro is that if you won't be filming for over 40 mins then the DVCAM mode is more 'robust' in that more tape has been used to record exactly the same information. So if you hit a tiny crinkle in the tape for instance, the disruption to the picture and audio will occupy less time on screen than if you'd been in SP mode.
If you shoot DVCAM you must be able to replay it, so don't shoot it if you want to give the tapes to others who only have access to LP and SP.
tom.
Craig Seeman June 23rd, 2004 06:08 PM
<<<-- Originally posted by Tom Hardwick : If you shoot DVCAM you must be able to replay it, so don't shoot it if you want to give the tapes to others who only have access to LP and SP.
tom. -->>>
Actually if you shoot DVCAM you can snicker when clients can't play them and then you offer to dub them to miniDV at $$$ per hour all the while telling them they got a great bargain because you shoot on pro format DVCAM rather than consumer miniDV. <grin>
Sony gibberish on why to use DVCAM over miniDV
"Why should I use DVCAM instead of Mini DV?
DVCAM vs. Mini DV / DV
- Tape Width and shrinkage specifications are held to tighter tolerances during manufacturing of DVCAM tape. This results in improved reliability with regard to Machine to machine compatibility (tracking) and for use in a wide range of environmental conditions.
- Dropout Ratio is decreased by up to 50%
- Protective locking album case for safe mobility and protection from adverse environmental conditions.
WHY SHOULD THE PROFESSIONAL USE DVCAM SERIES TAPE?
Because their reputation is in the media."
And now Sony has the super hightest DVCAM Digital Master
"It’s the only professional videotape with not one but two 100% active magnetic layers for 90% fewer errors than consumer DV tape. Because video error correction is so good , errors are sneaky. Even as the errors accumulate, you’ll think you’re fine. Your first sign of trouble can be a dropout that can break up the image on a one-on-one of a kind of take. So why risk it all? When it comes to your creative vision, demand DigitalMaster tape."
I like that "not one but two 100% active magnetic layers." Sounds like DoubleMint Gum or that drop of breath freshining Retsin in the middle or those processed foods with "natural flavors" listed in the ingredients.
Remember, "errors are sneaky."
Shuf Shukur June 25th, 2004 07:27 AM
is the quality better?
<<<-- Originally posted by Tom Hardwick : What would happen? You'd record 40 minutes of DVCAM footage. -->>>
Mike Rehmus June 26th, 2004 01:54 PM
<<<-- Originally posted by Shuf Shukur : is the quality better?
<<<-- Originally posted by Tom Hardwick : What would happen? You'd record 40 minutes of DVCAM footage. -->>> -->>>
No, it is exactly the same digital signal
Craig Seeman June 26th, 2004 06:15 PM
I do believe there are qualitative differences in the shell and the tape stock. Only over time and/or "rough" handling would DVCAM show fewer drop outs (not likely initially though). There's also less likely to be tracking errors. The digital recording itself is the same.
John Carey June 28th, 2004 11:48 AM
Yes, But
Yes, But i was talking about using DVcam mode or DV SP mode to record on REGULAR DV TAPES. NOT DVCAM TAPES.
john
Mike Rehmus June 28th, 2004 12:32 PM
John, WE UNDERSTAND and the answers remain the same.
