Realistic assesment of VX2000 v's 2100
Hello All
Now that the VX2100 has been in circulation for a few months, do those who have experience of both have any opinion on the 'improvements' in the 2100 over the 2000? I ask this as my local store has both and I am thinking of buying one, as a foil for my PDX10 (so as to multi camera stage events) Thanks P PS : There is a $500 price difference |
I have both a 2000 and a 2100. I have only shot one event so far with the 2100, so I don't have a great deal of experience with it. So far I have not noticed a great deal of difference.
Things I definitely like better about the 2100 are: -lens cover built into the hood (big plus!) -slightly better visual angle on the side LCD -less noisy in very low light Things I don't like as much on the 2100 -surface texture and color. The 2000 was smooth and silver. The 2100 has a textured surface and is gray. The texture may be better for minimizing reflections off the cam, but it feels gritty to me when I pick it up. Just a gut reaction. Others may prefer the new feel as it will make it harder to drop the camera. -the need to only use Infolithium batteries from Sony. I had purchased some F960 equivalents from Ebay not long ago that I planned to use with both cameras. They were under $40 and so far have worked perfectly with the 2000. Upon discovering that the 2100 rejected these batteries at power on, I have had to shell out $110 for a Sony 960. -the sensitivity of the viewfinder to the exact position of your eye. The magnifier makes the viewfinder look a tiny bit bigger, but if you shift your eye position a little, the viewfinder goes out of focus. This may be as much a function of the large eyecup that comes with the 2100 as it is with the magnifier (I'm not sure). I have always used the small eyecup with my 2000, and I find it easier to use. Things I'm not sure about yet: -improved sound? I never noticed issues with sound on my 2000, so I'm not sure that this will turn out to be a big advantage for me. BTW, the my 2100 and 2000 aren't identical with respect to auto white balance, AE, and color level. I have found that I can adjust out the differences in AE and color level by using the custom presets, and by using manual white balance I can then make the cameras take identical video. Hope that helps. |
Thanks for this.
Sounds like a good discounted VX2000 is the one to have then. !! Regards P |
I don't care for the new eyecup. I wish they had
a smaller one as an option. I've tried removing the eyecup permanently, but it's hard to see the viewfinder and I'm worried the glass will get scratched. Maybe I'll get use to the new one in time. New one gets in the way cuz of its large size, catches on everything cuz of the sticky rubber, and fogs the viewfinder quickly. |
Maybe one of the hoodman eyepiece hoods would work in place of the factory piece.
I like the large cup that is on the 150 just because I do shoot a fair amount out in the sunlight and it does make a major difference to me. |
Good details Alan. Can you clear up one point for me? The PD170 claims an improvement in the way the exposure wheel works - in that it puts twice as many steps into the aperture changes, making them less visible on screen. Is this so on the VX2.1k too? Or are the apertures bumped up or down in (very visible) half stop increments as in the VX2k?
If the VX2.1 follows the 170 lead in this respect, I'd go for it. If not I'd save the money and go with the VX2k. tom. |
There appears to be no difference in the number of wheel-controlled exposure steps between the VX-2000 and the VX-2100. This seems like it would be a simple firmware change to the camera, so I'm surprised that Sony didn't make this improvement on the 2100. Perhaps they were trying to maintain the difference between the pro-sumer 2100 and the more professional PD-170.
Having used both, I'd personally go with a 2000 for a $500 difference in price. |
